Psycho White
Discussion in '2nd Gen Builds (2007-2013)' started by PSYCHO WHITE TUNDRA, Mar 16, 2020.
  1. Mar 16, 2020 at 5:12 AM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA [OP] Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    Suspension, Wheels and Tires
    •6” ProComp Lift w/ Fabtec +6 rear shocks
    Wheel and Tire
    •20” Pro Comp Extreme Alloy Series 6047
    •35x12.50x20 Treadwright MT Claw II
    Sound System
    •80 rear seat deleted for sound system
    •15” Frankenwoofer (15”Sundown Audio Nightshade V3 with the motor off a 18” Sundown Audio Nightshade V3)
    •Skar Audio RP2000.1 Amp for Sub
    •Morel 400.4 Amp for Mids and Highs
    •6.5” Morel Maximo Ultra 602 rear doors
    •6x9 Polk Audio MM Series front doors
    •XS Power battery added to assist Optimum yellow top battery
    •Big 3 ground upgrade done 0g ground and 0g power (Total of five 0gauge grounds added)
    •Kilmat 80mil sound deadening on all 4 doors, roof and side mirrors
    Lighting
    •DiGo 52” straight light bar
    •4.5” Turbo SII fog lights retro fitted from 2016 Harley Streetglide
    Exhaust
    •TRD exhaust, 2nd cat and X Pipe delete
    •Straight pipe from 1st cat to rumble mufflers and dumped shy of rear axle
    Just Because Add-ons
    •Trendrun 150db train horn powered by two compressors
    •RGB Rocklights in fender wells
    378D36ED-AB7A-494E-9C42-AC111621CACD.jpg 554F355C-C90F-4CBB-8AB5-EBE2FED2DD5B.jpg 0BFC7FBD-9C36-4BD9-8F40-4124BB3B7863.jpg 7DCDF1EC-417C-4D5C-AD80-2D6D1E7B4E18.jpg
    Rica25 likes this.
  2. Mar 16, 2020 at 5:14 AM
  3. Mar 16, 2020 at 5:17 AM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    Thanks TXRailroads
  4. Mar 16, 2020 at 5:27 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Noice....Well played Sir!!!
  5. Mar 16, 2020 at 5:32 AM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    Thanks Toyofan87
    toyofan87 likes this.
  6. Mar 16, 2020 at 5:33 AM
    Mnorris1206
    08 tundra
  7. Apr 5, 2020 at 3:30 PM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    ha ha frankin woofer... did you get that from the sundown yardsale? i am still thinking of trying the surprize me... got 2 sd3 b-stocks in behind the seats right now.
