Psi on 35's
Discussion in 'Wheels & Tires' started by allstar617, Sep 12, 2016.
  1. Sep 12, 2016 at 5:25 PM
    allstar617
    allstar617 [OP] New Member
    Sy
    Boston,Ma
    2014 sunset bronze 1794
    Thule areoblade roof racks,Full Led conversion, rackarod lockable rod holders,Led bed lights,Lock'er down safe, 42" led light bar.......6112/5160 suspension lift Coachbuilder +3 shackles, shims and bushing set. Toyo open county AT2’s 295/65/20’s on stock black painted wheels..........
    sorry if this has been asked a million time, but was wondering what psi everyone eles is running on there everyday driver? When I had them installed they were set at 37 psi, and seem to look low
    Front
  2. Sep 12, 2016 at 5:28 PM
    I'd go with 40+ on the front. A lot more weight.
  3. Sep 12, 2016 at 5:31 PM
    I just realized you have hardly any rubber. I'd be more worried about 1" pot holes.
    Law323 and TheBeast like this.
  4. Sep 12, 2016 at 6:19 PM
    allstar617
    Sy
    Boston,Ma
    Ok I'll bump up the fronts over 40 and see you it rides
  5. Sep 12, 2016 at 6:21 PM
    allstar617
    Sy
    Boston,Ma
    I know especially in my area "Boston mass the bumpy roads" lol
    My problem is avoiding the curbs lol
  6. Sep 12, 2016 at 6:35 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I run 42 PSI on my Toyo's.
    SuperSilverTundra likes this.
  7. Sep 13, 2016 at 5:14 AM
    chphilo
    chphilo Tundra addict
    Western PA
    What is your max psi for your tires? My max is 80 and I run 45 normally. During the winter, I run 55 (well, if it gets really nasty, I air down somewhat).
  8. Sep 13, 2016 at 5:37 AM
    allstar617
    Sy
    Boston,Ma
    Max is 80, I was thinking about starting at 46 or even 50 and going from there, see how she rides and do the chalk test. Seems like a good starting point. Thanks for your input
  9. Sep 13, 2016 at 5:49 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    I run 40 all-around for normal driving and bump the rears up to 70 when towing my camp trailer.
  10. Sep 13, 2016 at 6:03 AM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    I'm on 37's max is 60ish and I run 38 in the rear 40 in the front.
  11. Sep 13, 2016 at 7:54 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    i run 42psi all around I had them at 38psi noticed at 42psi feels better and more mpgs
  12. Sep 13, 2016 at 8:00 AM
    scturndra
    scturndra New Member
    wall
    2012 tundra extra cab sr5 4.6v8
    I run 60 pi all the way around. Running Falken wildpeak 275/70/R18. I was told that 40 would work but looked like the sidewall was still smushed, so I bumped it to 60. The max for this tire is 80 psi.
  13. Sep 13, 2016 at 8:22 AM
    I run 32 all around. Even wear.
    If you're running 60, I hope that's when you're towing.
    bandit likes this.
  14. Sep 13, 2016 at 9:15 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I run 45-48 on my 275/70 toyo at's.
  15. Sep 13, 2016 at 10:20 AM
    allstar617
    Sy
    Boston,Ma
    More Mpg's I need that lol went from 13.1 to 10.9!!! Naturally fat heavy foot :)
  16. Sep 13, 2016 at 10:21 AM
    scturndra
    wall
    no I run 60 psi all the time. Why would you hope I was just doing that when towing?
  17. Sep 13, 2016 at 10:41 AM
    bandit
    bandit New Member
    Duh Tundra
    Are you running E rated tires? That is the only time outside of towing I could see you coming remotely close to running 60psi....That is wwayyyyyyyyyyy to high for daily usage though. Hell, even on my last set of E rated tires I still only ran 40psi
    Law323 and T-Rex266 like this.
  18. Sep 13, 2016 at 10:45 AM
    Your tires will not ware evenly. That PSI for daily driving is way too high, IMO. I'm also running M/T though. Not sure what you are.
    bandit likes this.
  19. Sep 13, 2016 at 11:30 AM
    scturndra
    wall
    I am running Falken wildpeak 275/70/R18 A3W's 10 ply
  20. Sep 13, 2016 at 11:31 AM
    scturndra
    wall
    yes they are E rated
  21. Sep 13, 2016 at 2:01 PM
    bandit
    bandit New Member
    Duh Tundra
    I just googled those and they say "MAX Inflation 65psi" That means don't run em at 60 or 65 lol. Those tires and your back will be a lot happier sitting around 40psi all 4 corners. And last longer at that pressure also.
    T-Rex266 likes this.
  22. Sep 13, 2016 at 2:09 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Dude you'll be hopping all over the place with that psi drop it down to 40-45, you'll find your ride is much more agreeable and able to take bumps a helluva lot better.
  23. Sep 13, 2016 at 2:13 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  24. Sep 13, 2016 at 2:13 PM
    csuviper
    Broomfield, CO
    Think im around 45 front and 38 rear
  25. Sep 13, 2016 at 4:47 PM
    allstar617
    Sy
    Boston,Ma
    Ended up going 45 up front and 42 in the rear, and noticed a smoother ride right off the bat!! Like night and day!!! "National tire and battery" one of the perfered installer I picked from tread depot's website had all four corners at different Psi's
    SMH from 32-37psi WTF!!!
    I knew I should of checked all four when I picked up the truck. Of course I checked the one that was at 37 and thought all of them would be the same. Thanks to everyone who chimed in.
    Law323 likes this.
  26. Sep 13, 2016 at 4:52 PM
    allstar617
    Sy
    Boston,Ma
    I'll still do the chalk test just to see, definitely want even wear and the 50k as advertised :)
  27. Sep 13, 2016 at 5:08 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    With new tires the psi can change pretty fast. Not sure if it's due to the rubber getting broken in or what but I filled up my new tires at 37 all around and after a month or so they seemed low so I checked, one tire was at 28 psi, highest was at 31. Filled them up to 45-46 and haven't had a problem since
  28. Sep 13, 2016 at 5:26 PM
    allstar617
    Sy
    Boston,Ma
    I think that's what happened because the fronts did look a lot lower then when I first had them installed.
  29. Sep 13, 2016 at 5:41 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yeah so did mine. At first I was pissed cause I thought I had a slow leak or something, but when I checked the others the rubber breaking in was the only logical reason I could muster. Killed a few brain cells thinking that hard LOL
  30. Sep 13, 2016 at 6:19 PM
    bandit
    bandit New Member
    Duh Tundra
    Tires have unique characteristics. Air expands in the heat and contracts in the cold. As you drive your truck, friction builds up heat and the air molecules inside your tires will start to expand. And on a cold day after the friction has caused your tire to expand, about 25 minutes later when you look again at your tire, it will look low. This is because the heat escapes from the tire when there is no direct heat or friction acting on the molecules. This is simply called putting tires through heat cycles. In racing we pay more attention to the actual cycle portion of it more and pay close attention to the temps of the tires as well. But for trucks, where there is more weight you will have more friction, this means the two fronts and the back left under the tank. But there will be more friction generated from the front because there are stronger forces acting on the front tires. Under breaking, added weight etc. If you want a easy way to keep them in check fairly easily. During the coldest part of your day/night when the tires are cold. Set the pressures about 5psi under what the goal PSI you want. Each manufacturer is different and each tire will be different dependent on wear type of tire etc. go on a 30 minute drive and check your pressures. Write them down, compare them to the first numbers and you'll know how much growth/expansion you're getting out of each tire. Then you can subtract that number from the goal psi you want, air your tires down to that exact number and you'll be accurate 99% of the time without worry. It also will make your truck track straighter down the road.
