PSI for excessive wear on the outside?
Discussion in '2.5 Gen Tundras (2014-2021)' started by John75226, Feb 19, 2024.
  1. Feb 19, 2024 at 11:58 AM
    John75226
    John75226 [OP] New Member
    2019 crewmax limited
    I've noticed a lot of folks here mention really high tire pressures (44psi, etc.) My door panel for a 2019 crewmax limited (4x4 w/20in stock tires) says 30/31psi.
    That said, I'm getting the excessive wear on the outside of the tire many others report, and I'm wondering if increasing the pressure would help? 31psi seems low, but that's what the door plate says.
    I'm curious what the rest of you folks run in your stock tires?
  2. Feb 19, 2024 at 12:11 PM
    Retired...finally
    I'm 35/38 and see even wear on my 18" Michelins. You remember the Ford Explorer/Firestone fiasco? That was in part due to Ford's insistance to use a lower than normal tire pressure for passenger comfort.
  3. Feb 19, 2024 at 12:11 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Ya I never understood that sticker mine says 30/33
    I run 40psi winter 45psi summer on 20's
  4. Feb 19, 2024 at 12:12 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    we talking stock OEM tires or aftermarket E's?
    HulkSmurf14 and InfernoTundra15 like this.
  5. Feb 19, 2024 at 12:31 PM
    bflooks
    bflooks New Member
    Metrowest MA
    This.
    Factory P rated tires typically run around factory recommended pressures, where different load ratings (E is pretty common) requires higher pressure. Mind you, a P rated tire may have a max cold PSI of 48-60, where an E rated tire is typically around 80 PSI.
    HulkSmurf14 likes this.
  6. Feb 19, 2024 at 12:37 PM
    John75226
    OEM stock on my 2019 crewmax: Bridgestone Dueler Alenza 275/55R20. An 18in stock was also offered on this model.
    I'm going to replace with Michelin LTX.
    BossDawg24, BoyHowdy and Dowloader like this.
  7. Feb 19, 2024 at 12:44 PM
    Dowloader
    Dowloader New Member
    I'm wondering the same, I just got a set of Michelin Defender LTX M/S2 on my 2020 1794 4WD and it changed the truck for the better, smoother ride, almost no noise and my MPG has been creeping up. I also did an alignment since my previous factory tires Michelin LTX AT2 were almost bald on the outer side. Costco installed the new tires and they put 35 on all of them, that was only 2 days ago and the truck has been riding so nice I almost don't wanna touch it but still have the same doubts as you.
    I'm stock 18" Rims and Tires are 275/65R18 116T
  8. Feb 19, 2024 at 1:38 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Running mine at 38 all four, 20 inch Nokians..so far wear looks good..
  9. Feb 19, 2024 at 2:28 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    If you are getting excessive wear on ONLY the outside, you might have an alignment problem. Low air pressure will wear excessively on both the edges of the tire.
    Retired...finally and bflooks like this.
  10. Feb 20, 2024 at 6:27 AM
    John75226
    had alignment at ~15k and 30k -neither were much out of spec. The outer tire wear seems to be common on these trucks even with proper alignment.
  11. Feb 20, 2024 at 6:40 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I think Toyota may had to compensate a low degree caster with higher toe-in to have at least some steering stability around zero. On my Volvo wagon caster and toe-in are twice of and half of Tundra's respectively, it can drive a mile straight without intervention and have no abnormal tire wear. Tundra is floating off the track on the highway and wears outer edges out, yes.
  12. Feb 20, 2024 at 7:44 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    might be excessive toe. I know the toyota spec says up to 18 or 20 is good, but I have read on here and experienced myself that the lower the toe the better, I think the sweet spot is around 13 or 14
    Biggest reason would likely be PSI and tire type tho.
  13. Feb 20, 2024 at 7:15 PM
    Rstreight
    Rstreight New Member
    Ron
    South Texas
    2021 MGM Platinum 2WD
    Face it our tucks are heavy!!! The OEM p rated tires they come on have soft sidewalls for ride comfort and flex quite a bit in cornering, the lower pressures Toyota "recommends" only exacerbates the problem on the steer tires.
    I increased the pressures in my OEM Bridgestones to 34/37, in my opinion the truck handles better and tire wear has looked good from 14k to the 42k I now have.
    Hopefully get another 10k out of these Bridgestone tires then going to Michelin Defender LTX M/S2, stock size, but that's a whole new discussion :monocle:
