PSI CHALK TEST RESULTS
Discussion in 'Wheels & Tires' started by Brandenmontoya10, Mar 28, 2016.
  1. Mar 28, 2016 at 6:40 PM
    Brandenmontoya10
    Brandenmontoya10 [OP] HE > I
    Branden
    2011 Tundra Charcoal Grey
    Did the chalk test, how do these results look to you guys who have experience with this method? I had my LT 285/ 70R18 open county MT set at 46PSI on my 2011 tundra with 6" lift and about 150-300 pounds of HVAC equipment in the bed.
  2. Mar 28, 2016 at 6:49 PM
    Drop a few pounds. Still looks like the inside is wearing more.
  3. Mar 28, 2016 at 7:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Appears the top 3 are of the rear. Need to drop pressure as ColoradoTJ said. The front looks almost even.
    Drop the rear to 40-42 and test both again but drive a little further. No turning. This will help wear the chalk a bit more so you can see the difference a little better.
  4. Mar 28, 2016 at 8:02 PM
    Brandenmontoya10
    Branden
    Thanks for the feedback!
  5. Mar 28, 2016 at 8:02 PM
    Brandenmontoya10
    Branden
    I will give this a go tomorrow! Thanks for your help
