proper way to turbo 200 tundrs
Discussion in '1st Gen Tundras (2000-2006)' started by LITTLE DOG, Aug 24, 2022.
  1. Aug 24, 2022 at 7:10 AM
    LITTLE DOG
    LITTLE DOG [OP] New Member
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    to do a 200 tundra turbow properly get a flex a light electric fan kit. gives better cooling and a lot of room for your cooler lines. use a 3uz engine has 6 bolt mains just put in h beam rods. 3uz has huge injectors and vvti cams and variable intake manifolds makes 90 hp moor stock. se my threads on this truck. it took 6months and a lot of trial and error to get it perfect. here to help not criticize. 814-323-2476
  2. Aug 24, 2022 at 7:55 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    Little dawg, you are the best thing to ever happen to this forum.
  3. Aug 24, 2022 at 8:46 AM
    Let's see some videos of that thing rippin'
  4. Aug 24, 2022 at 9:31 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    that picture of the 3uz is from way back in 2014, not yours. do you have picture of your turbo 3uz?
    Tundra2 likes this.
  5. Aug 24, 2022 at 11:34 AM
    LITTLE DOG
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    no that is not mine just thought that was cool and something to see shows what can be done with the 3uz. i will post pictures tomorrow of engine and truck so one thinks this is bogus shiii.
  6. Aug 24, 2022 at 11:35 AM
    Wait, is the engine in the truck above not a picture of yours?
  7. Aug 25, 2022 at 4:37 AM
    LITTLE DOG
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    picks of engine build and truck
    5N0W808 and texasrho83 like this.
  8. Aug 25, 2022 at 4:43 AM
    LITTLE DOG
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    yes vvti big fat pink injectors var induction . upper oil pan for 2uz tundra chaaa-ching . note metal timing belt covers not plastic. no fan pully bracket like 2uz is set up for electric fans. 6 bolt mains. motor has 1,400 miles when it was rolled and totaled lexus Ls 330.
  9. Aug 25, 2022 at 4:57 AM
    LITTLE DOG
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    yes this is real not bs
  10. Aug 25, 2022 at 6:08 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    That 3UZ is looking sweet! when do you plan to start the swap? what transmission will you use?
    I don't think anyone is saying you're lying, we just want pictures!
  11. Aug 26, 2022 at 3:49 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Nice work. :thumbsup:
    That turbo is huge. How much boost do you plan to run?
  12. Aug 26, 2022 at 6:46 AM
    LITTLE DOG
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    i have 2 3uz motors i have run one up to 43.8 psi it was a crazy ride/ like i posted trans is pissed. will run lexus gx470 trans at next swap oh yes i am getting very fast at swapping motors. and yes i have pics of both 3uz engines i bought from jdm. and have 2 2uz anybody need a 2uz?
  13. Aug 26, 2022 at 8:36 AM
    tvpierce
    Maine
    :eek2::eek2::eek2:
    Sweet Jesus! What do you run for fuel to keep it from pre-igniting? Have you been on a dyno? What are the hp/torque numbers?
  14. Aug 26, 2022 at 1:54 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    I've seen A340s blow at 8psi. How the hell did it even make it to that kind of boost without cooking it much sooner? I doubt an LX trans will handle that kind of insane power much better, might want to look into a turbo 400 swap, I remember Lextreme pulled it off a couple years ago. Also how did that motor withstand that kind of boost at 15.1/1 afr? That seems extremely lean even if you're pulling timing, lower compression and running q15 methanol. What compression are you running? What standalone are you running the motor with?
  15. May 19, 2023 at 10:49 AM
    LITTLE DOG
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    LEVEL 10 TRANSMISSION. SEEMS OK WITH THE TURBO YES WINTER IS OVER SO I WILL START PLAYING WITH THE TUNDRA AGIN. PS ANY BODY KNOW IF U CAN USE 2UA HEADS ON A 3UA CLOCK COOLIN JACKECTS DIFFERNT
    DJenerated and shifty` like this.
