Programming 2018 keyfob
Discussion in '2.5 Gen Tundras (2014-2021)' started by danz75, Oct 2, 2018.
  1. Oct 2, 2018 at 8:48 PM
    danz75
    danz75 [OP] New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Hi all, I'm in need of some help to program a refurbed 2018 H keyfob from ebay. Had the locksmith cut the key today and used techstream to add the key to the ECU and was able to start the engine.
    However, I cannot find any option that would allow me to program the lock/unlock buttons. Is the programming done by the insert key/close door method or is it hidden somewhere in techstream? I looked through every possible option and still could not find it.
    Anyone that has added a 2018 keyfob successfully? How did you program the lock/unlock buttons?
  2. Oct 2, 2018 at 9:13 PM
    buffaluphagus
    buffaluphagus —————————————
  3. Oct 2, 2018 at 9:39 PM
    danz75
    Everett, WA
    18' Cement SR5
    Thanks! This worked. Was searching pretty much every keyword I could think of but did not find this video. I'm going to file this for future reference.
    Thanks again!
  4. Oct 3, 2018 at 7:08 AM
    buffaluphagus
  5. Nov 2, 2019 at 12:35 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    can you grant me access to the video please. Thanks.
  6. Nov 21, 2019 at 11:37 AM
    jjadigo
    jjadigo New Member
    same here, can you grant me access to the video, please. Thanks.
  7. Jan 6, 2025 at 12:58 AM
    primeiro
    primeiro New Member
    Henk
    Netherlands
    thank you so much for this vid , i have been trying this for a couple of hours in techstream but no luck , going to try this
