Program keyless entry remote?
Discussion in '2nd Gen Tundras (2007-2013)' started by ethridgetrey, Mar 26, 2014.
  1. Mar 26, 2014 at 9:00 PM
    ethridgetrey
    ethridgetrey [OP] New Member
    2007 Tundra Limited CrewMax, 5.7L
    18" XD Addict 285 Nitto Terra Grapplers
    Hey guys. I bought my 2007 Tundra CrewMax second hand. It only came with one keyless entry remote, and I was able to buy another OEM off eBay pretty cheap. I've read the programming can only be done at a Toyota dealership, but it is $50 to do the 2 minute process! Does anyone know how to program the keyless entry remote on your own?
  2. Mar 27, 2014 at 5:33 AM
    Not that I'm aware of...
  3. Mar 27, 2014 at 4:40 PM
    ethridgetrey
    Thanks Sean! I'll keep researching. When I used to rock the Bowtie trucks I knew how to for my Silverado. Surely to goodness there's a way to do it ha!
  4. Apr 25, 2015 at 5:27 PM
    pacman_gptx
    pacman_gptx New Member
    Paco
    2012 5.7L Magnetic Grey Metallic Crewmax SR5 Texas Edition
    Interior LEDs, Cargo/Reverse LEDs, Foot Well LEDs, McGard Tailgate Anti-Theft, Pilot Stubby Antenna
    A few years back I had the same situation with my sons 4x4 trailblazer, I went to a local locksmith that advertised programming keyless remotes. Those guys pretty much have all the codes and you could probably get yours programmed and a spare for less than $50
  5. Apr 26, 2015 at 9:47 PM
    tundratrav82
    tundratrav82 Nevada Tundras
    travis
    winnemucca, NV
    2011 tundra limited TRD crewmax
    Limmo tint on all 3 rear windows, 20% in front two. 18" black ballistic rims with nitto tires Bike bar in the bed for my dirt bikes..
    yes.. a few yes back I had to buy a new fob for my Tacoma before I went tundra. I think I found it off a you tube vid bit there was a sequence of turning the key switch on and off during pressing the button on the fob a number of times.. its been a long while so you would have to google it or do some research.. not sure if its the same on tundrs though.. good luck
    ps there is no computer programming, the dealerships do the same
  6. Apr 27, 2015 at 3:27 AM
    rr3311
    rr3311 Tundra Magic
    Ohio
    2015 Bronze Tundra Limited Dbl cab 4x4
    Added Extang Solid fold tonneau cover Replaced backup lights with projector LEDs Cab LEDs Taconsha P3 brake controller mounted in dash
    Try this link.
    http://www.carandtruckremotes.com/h...eplacement-keyless-entry-control-remotes.html
    Black Wolf likes this.
  7. Apr 27, 2015 at 4:48 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Techstream software on your own laptop will do it, plus much more.
  8. Apr 27, 2015 at 6:00 AM
    I am in the same boat. Only got one key with remote when I bought my truck. Amazon has a chip key sold by Hot Systems with good reviews and you-tube instructions. "This chipped key blank will only work if your current key has a dot in the key blade near the plastic part,not a letter "G"." I know my key has the "dot" meaning it has the 4D-67 chip which will be compatible with Hot Systems chip key. There are many suppliers of chip keys on Amazon. Read the reviews before you buy. I would stay away from ebay. A lot of keys being sold without chips in them. Buyer beware. rr311's link above is a good one, a little more money but probably better than the Amazon route.
  9. Apr 27, 2015 at 6:51 AM
    scratchex
    scratchex New Member
    2015 Tundra Limited
    3" lift TRD Exhaust 20" Fuel Lethal Wheels Toyo AT Tires Black Flares w/ spikes
    I'm guessing the answer to this is no but is there a way to program the remote to automatically roll down your windows when you hold down the unlock button? I had this feature on a few of my previous vehicles & always used it during the summer to let out some of the heat before entering the vehicle. I'm guess it probably has to be done with an aftermarket alarm?
  10. Apr 27, 2015 at 7:05 AM
    The various You Tube instructions that I came across but have not tried involved inserting original key into the ignition turning it on and off a few times and opening and closing the drivers door a few times to set up for programming new key. There are specific sequences to perform for it to supposedly work. I saw two variances to this on You Tube but very similar.
  11. Apr 27, 2015 at 8:03 PM
    Not that I'm aware of, but on the limited and higher editions, if you place the key in the drivers side door, turn it and hold it'll open the windows and sunroof.
  12. Apr 28, 2015 at 3:49 AM
    scratchex
    2015 Tundra Limited
    I need to try that on mine & see if that works!
  13. Apr 28, 2015 at 5:30 AM
    I posted a video of it in the DIY/MOD section if you wanted to check it out.
    scratchex[QUOTED] likes this.
  14. Apr 28, 2015 at 10:18 AM
    rr3311
    rr3311 Tundra Magic
    Ohio
    It works on my 2015 Limited dbl cab
