Program ignition keys 2007 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Jbird2356, Nov 26, 2020.
Anyone know how to program ignition keys for 2007 tundra 5.7 limited 2wd
Poll closed Dec 10, 2020.
  1. Yes
    1 vote(s)
    100.0%
  2. I did it
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. Nov 26, 2020 at 12:56 PM
    Jbird2356
    Jbird2356 [OP] New Member
    2007 toyota tundra limited 5.7
    Help programming keys
  2. Nov 26, 2020 at 1:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You’ll need techstream to do it. Either the dealer can do it (and charge you usually) or using a knock-off cable and illegitimate version of the software that you can get off Amazon, eBay, and any number of other places.
    For a 2007, any firmware v1.4 cable and version of techstream currently out there with the knock off cables will work, but a lot of the older versions require a bunch of screwing Aaron’s to get them working on a computer running Windows 10 x64.
    One advantage of having the cable is you can also disable the seat belt warnings while you’re in there.
    Oh, and welcome from the wet side of WA.
    Cruiserpilot likes this.
  3. Nov 26, 2020 at 1:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Other things to make sure of:
    Your original key has a letter or symbol stamped in the shank near the plastic - that is the transponder code. A dot (“o”) i think is the one for the early Gen2, and G and H is common in newer models. Either way, you HAVE to get the new key with the same transponder code (if you’re buying off eBay or elsewhere). That’s the chip that will work with the immobilizer.
    For the remote lock/unlock, you’ve also got to make sure the replacement has the same FCC ID and stuff.
    I did it in my 2008 when I got one of the switchblade-style keys off eBay. I was able to have a local locksmith cut the key and then did all the rest myself.
  4. Nov 26, 2020 at 2:31 PM
    Jbird2356
    Thanks! I'm going to try and get Techstream. I've got the correct keys they all match and A1 lock's software wouldn't program them but I'm not sure what they used. They suggested a garage that might have some aftermarket software. Now we'll see if I can do it.
  5. Nov 26, 2020 at 2:41 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Easy squeezy with techstream.
    If you were close, I’d offer to do it for you.
  6. Nov 27, 2020 at 8:34 PM
    ICECOLDBEER
    ICECOLDBEER New Member
    2009 Toyota Tundra TRD Off Road 5.7 4x4 Double Cab
    I'm also interested in this. My key has an "o" stamped into it. And the remote FCC is: GQ43VT20T.
    Do you have links to the key/fob/ techstream cable? I'd love to disable the seat belt alarm as well lol.
    Also my only key is technically the valet key so it wont lock/unlock the tailgate and glove box. That must just have to do with the way its cut though I guess?
    I would be happy if it just started the truck though. :)
  7. Nov 30, 2020 at 5:52 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    Lowes may be able to do it for free. My autel scanner wouldn't do it though it's supposed to (I think I screwed up on menu selection for g or dot). Our 3 year old snap on scanner had no trouble at work. Any shop with a reasonably new scanner should be able to do this for you.....
