ProComp Preload Spacer Removal
Discussion in 'Suspension' started by Kriph, Mar 25, 2022.
  1. Mar 25, 2022 at 3:03 PM
    Kriph
    Kriph [OP] New Member
    2014 CrewMax 4x4
    I needs some advise from the suspension gurus. My truck has what i believe to be the 4in lift from ProComp. It has a 3in coil spacer (Above the Coil) and 1 1/4" preload spacer (In Coil).
    I need to replace the front struts soon and would like to eliminate the preload spacer to improve the ride. More than likely will go with Bilstein 5100. Truck is used as daily driving and towing.
    1. How much lift does the 1 1/4" preload spacer provide? I emailed ProComp and they just sent me the install instructions for the 4in kit.
    2. Would using a lift spring be better than increasing preload using the adjustments on the 5100?
  2. Apr 19, 2022 at 2:00 PM
    Kriph
    2014 CrewMax 4x4
