Procomp 6 or 7 in lift with 35s
Discussion in 'Suspension' started by Kdubz, May 17, 2019.
  1. May 17, 2019 at 10:17 PM
    Kdubz
    Kdubz [OP] New Member
    Arin
    2017 TSS TUNDRA CREWMAX 5.7 v8 4x4
    Bilstien Struts to level
    im ready to pull the trigger I would just like to see pictures or your tundras with either of these setups so I can make my final decision thank you.
  2. May 18, 2019 at 2:19 AM
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Procomp 6in lift w 35's 30in grill light bar Bac bed cover Taco tunes sq1 sound system Tinted windows Custom Masonic grill.
    I have procomp w 6in lift a 35s. 37 is too much in my opinion. 20190516_122916.jpg
    Inquiringone and jeremyd like this.
  3. May 18, 2019 at 4:35 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Here is two with Procomp 6 inch lifts. The red one is mine and the other is a friends.
  4. May 18, 2019 at 4:44 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Welcome to the forum! I have a 7” pro comp lift on 37” tires. The higher you go and the larger the tire you go, the more money you’ll spend. The larger tires will slow your truck down more, if you do not re-gear your truck. I would give David Ekstrom at Ekstrom Designs a call if you want to get a smoother ride out of your truck. He sells a few things to help improve the pro comp lift.
  5. May 18, 2019 at 6:14 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
  6. May 18, 2019 at 7:57 AM
    Bigdog
    Bigdog New Member
    2014 sr5 tundra 4x4
    7 inch pro comp lift 37 12.5 nitro ridge grapplers 639 k&n cai hyperforce interceptor tuner
  7. May 18, 2019 at 10:36 AM
    TXTundra2722
    2015 Black Tundra
    7 inches is always better than 6 inches anyday! :militarypress:
  8. May 18, 2019 at 11:15 AM
    1UPPER
    TEXAS
    Flux capacitor!
    That’s what she said. :rofl:
    TXTundra2722[QUOTED] likes this.
  9. Sep 20, 2019 at 6:12 AM
    Lunchbox94
    Lunchbox94 New Member
    2012 Rock Warrior
    4.5” BDS suspension Lift, 35x12.50 Toyo RTs, 20x10 Fuel Kranks
    I’m running 35x12.50 toyos on a 4.5” BDS suspension lift on 20x10 wheels. No rubbing at full lock, had to trim little plastic and take off front flaps
