Problems with injector pulse after rodent damage
Discussion in 'Electrical' started by Occidentalis, Jul 21, 2025 at 6:04 AM.
  1. Jul 21, 2025 at 6:04 AM
    Occidentalis
    Occidentalis [OP] Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Hi. Took the 2015 to the shop. 5.7l TRD pro
    Rodent destroyed driver side fuel rail harness. I bought a new harness piece and repaired the old one. After replacing, cylinder 1 will not fire with either the original or replacement part. Using a noid light, cylinder 1 won't light up. They tried replacing the injector, looking for more rodent damage, but can't find anything. The next thing they want to try is to replace the ECU, which I am very skeptical about.
    This is the closest I can find to a similar problem but there are no shared answers.
    https://www.tundras.com/threads/no-fuel-injector-pulse.103877/
    Looking for any insight before i throw an expensive part at it, erase my tune, etc
  2. Jul 21, 2025 at 6:46 AM
    You purchased a new harness and tried that right? Your post made it sound like you took the new harness and repaired the factory one that was damaged.
  3. Jul 21, 2025 at 6:48 AM
    JRS
    JRS New Member
    2012 DCLB
    I'd first check for ground continuity to make sure you aren't shorted somewhere. If that isn't the issue, then this popped up: https://www.youtube.com/watch?v=rLMEYgEb2Lw
    Looks like you'll need to swap a transistor. I checked briefly to ID the one being used but "C5664" seems obsolete now. You'll have to find the original datasheet to spec a replacement.
    Occidentalis[OP] likes this.
  4. Jul 21, 2025 at 6:52 AM
    Occidentalis
    North Florida
    I did both. I purchased a new, used harness as well as repaired the old copy of the old harness to make sure the replacement wiring part wasn't bad.
  5. Jul 21, 2025 at 6:57 AM
    Occidentalis
    North Florida
    Interesting, I guess this does happen? The ecu is supposed to be very protected from shorts like this according to the people I talked to. I think it will be easier to send it in for repair or replace it than to fix it.
  6. Jul 21, 2025 at 6:58 AM
    So I would be tracing lines from the ECU and checking continuity.
  7. Jul 21, 2025 at 6:58 AM
    Occidentalis
    North Florida
    They've had it apart three times, they can't find continuity issues even though that seems like the obvious fix
    ColoradoTJ likes this.
  8. Jul 21, 2025 at 7:01 AM
    I have sent out a few ECU's for repair with good results. Think it cost 250.00, but it's been a while. The place was in Florida.
  9. Jul 21, 2025 at 7:02 AM
    Occidentalis
    North Florida
    I found $650 just now and am in Florida, if you can find a company name I'd probably use them, ty
  10. Jul 21, 2025 at 7:04 AM
    Looking now.
  11. Jul 21, 2025 at 7:05 AM
    JRS
    JRS New Member
    2012 DCLB
    If the dealership, or you, don't have experience with swapping ICs, I wouldn't start learning on your ECM unless you're willing to take the likely risk that it won't work and you'll need to replace. But before buying a new one, needing the VIN programmed, and getting your tune ported, I'd drop it off to an electronics repair, or a phone repair place. Swapping out an SOIC is actually very easy with the right tools and a bit of experience. It doesn't take an automotive specialist, just a hot air gun, solder gun, flux paste and copper braid.
  12. Jul 21, 2025 at 7:06 AM
    I'm pretty sure it was this business.
    ECU Exchange
    https://g.co/kgs/zJZq9Zr
  13. Jul 21, 2025 at 8:49 AM
    Occidentalis
    North Florida
    The trick there is finding the right resistor. I'm not sure how I'd go about doing that unless the shop I took it to had some idea. I'm willing to give it a shot but on that path am stuck at "finding the data sheet" you suggested in post #3
    TJ, ty for the lead but that company said they couldn't help me and suggested A1 Cardone.
    Ecu part is: 896610cp45
  14. Jul 21, 2025 at 9:05 AM
    JRS
    JRS New Member
    2012 DCLB
    *transistor
    Let the electronics repair guy figure that out. The replacement will have to match the pinout and allowable voltage ranges, which isn't something you want to risk getting wrong.
  15. Jul 21, 2025 at 9:09 AM
    Occidentalis
    North Florida
    Yes, transistor, sorry. I'm just thinking that a cell phone repair store is going to decline unless I tell them exactly what to do. Automotive based electronics repair is a specialty that I'm not sure we have locally. The auto electronics shop I've used in the past would diagnose to this point but then probably just swap parts. Maybe you know a place I could send it? I'm in North Florida, 32303
  16. Jul 21, 2025 at 9:38 AM
    JRS
    JRS New Member
    2012 DCLB
    No, sorry, I don't. Unsure about the cell phone stores because I've never used one - was just thinking out loud since there are numerous in every major city and they do this exact work. Worth a call at the minimum. If they decline then look for a general electronics repair shop.
  17. Jul 22, 2025 at 10:22 PM
    Occidentalis
    North Florida
    I bit the bullet and ordered a replacement ECU from Fred Anderson Toyota. It was that same online parts storefront but with the best combination of no tax + free shipping. Hopefully this fixes it and I can then fix the old ECU at my leisure or just deal with getting my tune put back on.
