Problem with back up camera
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraTrey0518, Apr 18, 2020.
  1. Apr 18, 2020 at 7:05 AM
    TundraTrey0518
    TundraTrey0518 [OP] New Member
    Trey
    2012 white tundra rock warrior crew max
    Black housing head lights, yellow fog lights, blue HID low beams BULBS , yellow LED high beams bulbs , yellow LED fog light bulbs,LED parking light bulbs, chrome bull bar, billet front grill, badge delete, 2 inch front/back wheel spaces, tinted windows, Injen cold air intake, Jet MAF, black housing third brake light, aftermarket tag light housing, kicker speakers
    I’m having issues with my back up camera. I purchased my 2012 rock warrior tundra used (obviously)back in November of 2019. Ever since I got it the rear camera has not worked. That being said, when I put the truck in reverse it seems like the back up camera doesn’t even try to engage. The screen on the dash doesn’t change nor go blank and it is a factory Toyota head unit. Does anyone have any insight on this? Could the camera have been disabled or turned off? I just find it odd that there is no change in display when the truck is put in reverse. Any help or suggestions with this is appreciated!!! Thank you!
  2. Apr 18, 2020 at 7:48 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My 2010 SR5 oem camera display is in the rear view mirror. Not sure if yours is different.
  3. Apr 18, 2020 at 7:59 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Mine is in the mirror as well, but i think that was standard for trucks with backup cam, without factory nav (‘10-‘13). When the camera isn’t plugged in, and you shift into reverse, the screen in the mirror turns blue. I would expect the factory head unit to do the same thing, but can’t speak from experience.
    Maybe it’s not getting the reverse signal from the shifter?
    Might be a silly question, but you have the camera in the tailgate handle, correct? The plug is under the truck next to the spare tire. You could check the connection there.
  4. Apr 18, 2020 at 9:35 AM
    TundraTrey0518
    Trey
    Yes it is in the tail gate handle . I will check the plug under the truck when I get it back today. It’s currently at Toyota getting tired and alignment.
  5. Apr 20, 2020 at 6:56 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    I am currently experiencing the same issue i ordered a camera thinking it was that and it wasnt. I went looking if it had a fuse also and found nothing.
  6. Apr 20, 2020 at 7:26 PM
    TundraTrey0518
    Trey
    I actually got under the truck yesterday and found that the plug was undone. I plugged it back up and it began working again.
    Civiceg94 likes this.
  7. Apr 20, 2020 at 7:27 PM
    Civiceg94
    NYC
    damn lucky you lol
  8. Apr 20, 2020 at 7:33 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    If your plug is plugged in at the tailgate the other plug is located above the rearview mirror in the ceiling console. If you have the sunglasses drop down you probably need the rear view mirror with the screen. The other type is a screen in the ceiling console right above the rear view mirror closest to the windshield. There are 4 screws to take the console down, two under the sunglasses holder, or screen, and two under the rear lights, if it's a second gen.
  9. Apr 20, 2020 at 7:38 PM
    Civiceg94
    NYC
    Mine is in the ceiling with the sunglasses holder. I used a panel tool to remove the monitor to check the rear plug and everything was fine. So you think the monitor is bad on the truck? Finding the monitor i have is hard especially any information on finding the fix for it.
  10. Apr 20, 2020 at 7:43 PM
    sf319
    sf319 New Member
    Utah
    It could be, I have heard of people swapping out the console screen for the mirror screen from a Sequoia. I ended up installing an after market stereo on my '07. Just tapped into the video up in the console and ran a wire down to the back of the head unit. It was easier, than troubleshooting the screen, though the tap was not easy. There is a forum post on one of the other sites, I will see if I can find it again.
    Civiceg94[QUOTED] likes this.
  11. Apr 20, 2020 at 7:48 PM
    sf319
    sf319 New Member
    Utah
  12. Apr 20, 2020 at 8:00 PM
    Civiceg94
    NYC
    Awesome thank you. i put a radio before but took it out because i have the limited 07 and the jbl system didnt like the pioneer radio so i lost interest
  13. Apr 20, 2020 at 8:07 PM
    sf319
    sf319 New Member
    Utah
    Also, this might help
    Yeah, my wife's Sienna has the JBL, it's a pain, there are a lot of extra peices you have to buy. I went to Crutchfield.com found out all the components and then bought the peices off of Amazon.
  14. Apr 22, 2020 at 11:01 PM
    Canine86
    Canine86 New Member
    2012 Tundra Limited mine freezes at times and is cloudy. Camera is in the tailgate and the monitor is on the dash.
  15. Jul 26, 2020 at 6:39 PM
    Jrider1365
    Jrider1365 New Member
    2012 Tundra Crew max
    Got 2012 tundra the the tailgate camera and the screen in the rear view mirror. The camera stopped working about a year ago. When the truck goes into reverse I get the blue screen for a few seconds and then it goes blank. Every now and then I get a really bad picture on the screen that lasts for a few seconds but it only works randomly. I checked the plug under the truck, and even removed and checked the camera in the tailgate. Not sure if there is a switch connected to the shifter. Would love to get a wiring diagram so I could follow it though from one end to the other. Anyone else have this problem and then get it fixed?
