Problem remains even after changing plugs and coils
Discussion in '2nd Gen Tundras (2007-2013)' started by Mcfetridge89, Oct 6, 2021.
  1. Oct 6, 2021 at 8:20 AM
    Mcfetridge89
    Mcfetridge89 [OP] New Member
    Michael
    2008 Toyota Tundra 5.7
    My truck has a misfire on 1&2. Changed plugs and coils. Swapped injectors. No change. VSC flashing, traction control on, hi/lo flashing. Check engine light flashing. I’m going to do a leak down and compression test, thought I’d throw this out there and see if anyone has this issue. Thanks for any help!
  2. Oct 6, 2021 at 9:41 AM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Toytec Ultimate kit w/ Bilstein Fabtech UCA TRD stabilizer Boss shocks - Rear Airlift wireless one 35x12.5x20 Nitto G2 Grappler
    Are you sure it isn't an air injection valve issue? I had all those same symptoms with the all the lights on the dash flashing and it caused my truck to go into limp mode. I purchased and override kit on ebay and haven't had issues since. Sounds like you know way more about engines than me, just comparing symptoms.
  3. Oct 6, 2021 at 9:55 AM
    Mcfetridge89
    Michael
    I just looked into that. The only thing is that when I ran the codes it started with misfire #1 and now it says random multiple misfire and started on cylinder #2.
  4. Oct 6, 2021 at 9:56 AM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    What are the codes?
  5. Oct 6, 2021 at 9:57 AM
    Mcfetridge89
    Michael
    P0302 at first then P0300, P0301
  6. Oct 6, 2021 at 10:07 AM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Man, I don't know. I have a code reader and can go back and look at the history to see. I feel like it pulled those same codes but I'm not sure sure
  7. Oct 6, 2021 at 10:30 AM
    Mcfetridge89
    Michael
    Just found this guy with the same problem. He mentioned a capacitor discharge. Going to give it a go.
  8. Oct 6, 2021 at 10:38 AM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Good luck! Wish I could help more. Someone in here will be able to help more then I
  9. Oct 6, 2021 at 11:07 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Hope that helps, but if it doesn't, you might try posting in the Ask the Toyota Mechanic and see if @Ruggybuggy can help.
  10. Oct 6, 2021 at 11:13 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Before you do anything clear all the codes, run the truck and address the codes that come up first.
    Start simple then escalate. When was the last time run changed the spark plugs? How many miles on the truck?
  11. Oct 6, 2021 at 6:20 PM
    Mcfetridge89
    Michael
    Cleared up all codes. Same things come back. P0300, P0301, P0302. Idles about 950 and shutters hard even up to about 3,000 then smooths out alittle. Swapped coils and plugs and injectors. Still no change and the LO Is flashing vsc flashing check engine light flashing trac off.
  12. Oct 6, 2021 at 6:28 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    So you have misfires on cylinder 1 and 2 with multiple misfires? Do you have a way to see the data stream and check which cylinders are misfiring?
  13. Oct 6, 2021 at 6:30 PM
    Mcfetridge89
    Michael
    I have a verus but it hasn’t been loading for some reason. I found cylinder 5&7 spark plug tubes full of oil. Oh and fuel pressure is good
  14. Oct 6, 2021 at 6:30 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Don’t be concerned about the other warning lights. Toyotas light up like a Christmas tree when CEL is flashing.
    Sundog and 15whtrd like this.
  15. Oct 6, 2021 at 6:33 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When the tubes are full of oil the high voltage jumps to ground and never fires the plug. Your going to have to fix the oil leaks and replace the boots on the end of the coils.
    Ktate, Sundog, Sumo91 and 1 other person like this.
  16. Oct 12, 2021 at 5:27 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    The oil leaking could be a issue but I'm not 100% sure on it but leaking oil is never a good thing. Should address the oil leak issue no matter what.
    1.) is your battery terminals clean and tight also grounds tight / non corroded.
    2.) is your your battery getting 13.2-14.8v while running
    3.) air filter clean?
    4.) is each spark plug firing (individually test them) and coil.
    5.) what do the plugs look like? New , grey , black or mega gap the size of the Grand Canyon?
    6.) are each fuel injector firing on time and is the spray pattern correct?
    7.) find something that can hold fuel thats clean and get a sample of the fuel from the injectors about 1oz or 2oz and let it sit over night this will allow water to separate if there is water in the system/check conditions of the fuel.
