Pro rims vs. offroad
Discussion in '3rd Gen Tundras (2022+)' started by Rb123, Sep 4, 2023.
  1. Sep 4, 2023 at 11:07 AM
    Rb123
    Rb123 [OP] New Member
    Washington
    22 trd off-road crewmax mgm
    Bfg at 275/70r18 Lowmax Bumpershellz grill
    I’m buying some used pro rims. Could someone chime on any differences? Will the lug nuts from the offroad fit? Are they the same offset and width???
  2. Sep 4, 2023 at 12:25 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    if the current and upgrade rims are alloy the lug nuts will fit. not sure what lug nuts you have and plan to use (silver / black) as the new black lug nuts are 22mm socket. The '22 and '23 model year with silver are 21mm socket. No big deal but you don't want to interchange the two as they will affect balance. Take a look in the Tundra Garage -Wheel section for a pic I posted with part number Toyota is using to source the black lug nuts which are 22mm socket - maybe it will clarify my ramble. Long story short is you have all 24 lug nuts from your rims and don't need others you should be fine. The alloy lug nuts from Toyota all have the same thead and pitch.
  3. Sep 4, 2023 at 2:43 PM
    Rb123
    Washington
    Sr5
  4. Sep 4, 2023 at 9:22 PM
    Rb123
    Washington
    Thanks
    ryanwgregg likes this.
