PRO OWNERS please measure at leaf springs?
Discussion in 'Suspension' started by gosolo, Jul 9, 2017.
  1. Jul 9, 2017 at 1:30 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    I could sure use some information! If anyone with a stock Pro and no load in the truck could make a measurement: distance from bump stop to frame., I could compare to mine?
    Any information about how flat they sit stock would be appreciated too, especially with a picture.
    I'm measuring 3 1/2".
    I have added the 3 leaf Icon helper packs that replaced the middle 2 factory leafs, but the springs are still pretty flat and actually have a slight recurve double bend. IMG_0601.jpgIMG_0605.jpg IMG_0604.jpg
    I'm wondering if I should have gotten a custom Deaver set?
    Thoughts?
  2. Jul 9, 2017 at 2:03 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I sit really flat now with stock. I'm going to upgrade to custom packs as soon as your check shows up
  3. Jul 9, 2017 at 2:55 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Check is in the mail!
    Two problems: you don't have a Pro and you have a pretty heavy static load, correct? The SR5 springs you do have may be close but the spring arc on the un loaded truck is a big part of my question.
  4. Jul 9, 2017 at 3:39 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Yes, I carry a heavy load regularly, that's why I'm upgrading. Its an SR5 TRD, which if im not mistaken mifht be a different leaf than standard SR5. Your arc I'm unsure of though I'm not sure the PRO has a different leaf pack than TRD, does it? Im certainly not sure of what goes on any of them. Don't you pull a heavy camper? That might tax it a bit.
    dcsleeper408 likes this.
  5. Jul 9, 2017 at 3:56 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm running with a static load of about 1100lbs: shell, tool box, tools, sliders, winch & mount, transferflow tank& gas, skids. I'm pretty sure the stock Pro is the same as the SR5 but not positive. I'm hoping someone with an unloaded stock Pro will chime in with a picture and a measurement.
  6. Jul 10, 2017 at 7:23 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I found this old thread and maybe we are both okay with our current situation. A measurement from a stock unloaded truck would be nice confirmation though,
    https://www.tundras.com/posts/68682/
  7. Jul 10, 2017 at 7:39 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I read that a while back too. I also had a Tacoma that flattened to the bumpstops after one road trip. I've heard Toyota leaf springs are cheap too, with little to no curvature giving the feeling that they are flatter than they are. I'm 100% sure that I'm riding at least 2 inches lower than when I installed my lift. I'm visually sagging in the rear after my moab trip. I was parked next to some tundras at Toytec a few weeks ago and was comparing trucks. Mine have definitely flattened and I need a replacement pack. I don't ride the bumpstops like in my Tacoma but I definitely want more support for what I use mine for.
    You're probably ok unless you're towing. Don't you pull a camper??
  8. Jul 10, 2017 at 7:41 AM
    Eclipsed & Floating
    Voluptuous Whitey
    What size is your transferflow and where does it ride?
  9. Jul 10, 2017 at 7:59 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm rarely towing. I have a small pop up tent camper suited well to off road, a 26' travel trailer with wd hitch and a little utility trailer.
    The transferflow is 46g and replaced the stock 26 gal tank, between the steel and extra fuel it adds about 200lb
  10. Jul 10, 2017 at 9:43 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Alcan custom pack is $750
    gosolo[OP] and dcsleeper408 like this.
  11. Jul 10, 2017 at 11:01 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Can you link to what Alcan pack that is?
  12. Jul 10, 2017 at 11:01 AM
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
    I'm currently at work, but I can take a picture of mine when I get home if you still need it by 5pm it is 2pm at the time of writing this. I have a stock 2017 PRO with no load.
    gosolo[OP] likes this.
  13. Jul 10, 2017 at 11:04 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That is much appreciated! Take it from me, if you're modifying your rig, take lots of "before" pictures and measurements. Afterward you're never sure what you started with!
  14. Jul 10, 2017 at 11:06 AM
    niru316
    niru316 New Member
    Haha ya I bet... All I have right now is TRD Sway Bar but I do have some plans lol
  15. Jul 10, 2017 at 11:23 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    All they really do is custom. If you go to their website there is a pretty extensive questionnaire you fill out. They review it then get back to you regarding any additional questions they may have.
    The $750 quote I got was for constant 300lbs and no lift.
    gosolo[QUOTED][OP] likes this.
  16. Jul 10, 2017 at 12:45 PM
    niru316
    niru316 New Member
    NM do not expect a picture from me tonight... Florida decided it wanted a down POUR... Im not even going to make it back to my truck without being soaked... lol Maybe tomorrow... or somebody else will post a picture lol
  17. Jul 10, 2017 at 12:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Dang, wish we could get some of that here! We finally got a few scattered showers last night, first in over a month. All AZ is a tinderbox!
  18. Jul 10, 2017 at 12:52 PM
    niru316
    niru316 New Member
    Ya wish i could give it to ya... Its been nothing but down pour for the last 2-3 weeks... I can barely get out there after work to cut my grass if im lucky...
  19. Jul 10, 2017 at 2:37 PM
    Jaywhy
    Jaywhy Old Member
    Jeff
    2016 SW TRD Pro CM
    I'm 3.25" from top of stop to frame. No load, never been loaded with anything super heavy, never towed anything.
    gosolo[OP] and joonbug like this.
  20. Jul 10, 2017 at 2:55 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This is good to know. When I made the decision to go with the shackles and Icon packs it was instinctive not scientific. But based on what you're measuring, I have almost exactly the same suspension travel both upward and downward as when original. This is great news considering the static load.
    If you're accidentally laying under your truck admiring all that pro coolness and take a picture or 2 I'd very much like to see how flat they are!
  21. Jul 10, 2017 at 6:03 PM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    My truck is essentially a brand new Pro without any modifications. I measured (pointy end of bumpstop to frame) the best I could in the garage and it's definitely more that 3.5" and probably closer to 4". I've never had anything heavier than a can of trash in the bed. I did measure the rear and front fender well height at 39 in the rear and 38.5" in the front. The leaf spring pack was almost flat but did have a little arch very similar to the picture above. The truck was sitting perfectly level when I measured it.
  22. Jul 10, 2017 at 6:17 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Thanks for your response, I appreciate the picture too. I'm going to continue to monitor my springs and will measure to see if there's a difference between when the fuel tank is full or empty. I'm feeling confident that the set up is right, for now. All the weight is bad for mileage too.
