Pro Grille and Bilstein 5100's on finally
Discussion in '2.5 Gen Tundras (2014-2021)' started by ttc06, Aug 4, 2018.
  1. Aug 4, 2018 at 6:53 PM
    ttc06
    ttc06 [OP] New Member
    Missouri
    2016 Tundra SR5 TRD Package
    I went with the 5100 in front and back. Highest setting up front and 1" block in the back. Now I just need to do something with the front bumper.
    side note: I took my truck in today to have them look at my front rotors because i was having vibration braking. They ended up turning all four of them. Truck only has 26,000 miles on it. Any of you guys have rotor issues?
  2. Aug 4, 2018 at 6:58 PM
    Looks good!
    trdprobped17 likes this.
  3. Aug 4, 2018 at 7:00 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    And this has exactly what to do with installation of a pro suspension and grill?
  4. Aug 4, 2018 at 7:11 PM
    ttc06
    Missouri
    nothing, i was simply showing what the truck looked like since i put new suspension and the pro grille on. i didn't mean for this to upset you so much sweetie. i love the hardos on this forum.
    trdprobped17 and Part_time like this.
  5. Aug 4, 2018 at 8:21 PM
    Borgs
    Borgs New Member
    PA
    I think he was suggesting the pro grille warped his rotors. That’s how I took it anyway. The same thing happened to me when I put on my pro grille. Wicked torque and wicked shimmy.
  6. Aug 4, 2018 at 8:27 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have just around 32k and have some shaking in hard breaking over the last couple weeks. Did they turn the rotors under warranty? I'm thinking I need to get it done.
  7. Aug 4, 2018 at 8:27 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    The dealer turned the rotors? I doubt that highly. There is a TSB on rotor warping on the 3rd gens. If anything they replaced with better parts.
  8. Aug 4, 2018 at 8:32 PM
    Pudge
    CT
    I did not know there was a tsb on the rotors? Mine seem to need to be turned. Maybe I'll call and see if I can get them replaced. Do you by chance know where to find the tsb's for our trucks?
  9. Aug 4, 2018 at 8:33 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Stand by. I also do not think they turn them. Nobody does that anymore.
  10. Aug 4, 2018 at 8:35 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    tinman10101, Pudge and trdprobped17 like this.
  11. Aug 4, 2018 at 8:36 PM
    trdprobped17
    trdprobped17 New Member
    Toyota Tundras don’t come with good brakes. I had vibrations around 15k miles. All the Tundras and Sequoias that I have ever owned had that problem. Had to change them all out for heavy duty crossed/drills. Those seemed to work best for bigger vehicles.
    tinman10101, Pudge and BTBAKER like this.
  12. Aug 4, 2018 at 8:38 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Yea, I’ve been shopping brakes but I think I’ll have them do the TSB and buy myself some time.
    Skippy and trdprobped17[QUOTED] like this.
  13. Aug 4, 2018 at 8:40 PM
    Pudge
    CT
    BTBAKER[QUOTED] likes this.
  14. Aug 4, 2018 at 8:41 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Same thing here, pretty minor though. I may replace my front rotors.
  15. Aug 4, 2018 at 8:42 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    No worries! Get it done. I have an appointment Tuesday with Toyota. I’ll let you know what they do.
  16. Aug 4, 2018 at 8:42 PM
    Pudge
    CT
    Awesome thanks. Let me know how you make out.
    tinman10101, trdprobped17 and BTBAKER like this.
  17. Aug 4, 2018 at 8:45 PM
    trdprobped17
    I agree. Don’t get upset if you brakes still vibrates within a few thousand miles after they do whatever they do. It’s just a Toyota thing! They aren’t known for their brakes. In fact, their brakes are one of the first things that high performance experts always replace whenever the modify Toyota vehicles. I was very surprised last year at SEMA, when saw the aftermarket brakes that Toyota had on their concept vehicles and lexus’
    Pudge and BTBAKER[QUOTED] like this.
  18. Aug 4, 2018 at 8:51 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    You have any suggestions for a good set up? I was looking at SP performance. They have 25% off entire order and seem to be legit.
    trdprobped17[QUOTED] likes this.
  19. Aug 4, 2018 at 9:22 PM
    trdprobped17
    I’m running EBC on all my Toyota trucks and SUVs. Here’s a link from Carid. You may be able to get the same kit for a little less elsewhere, but, Carid is a trusted seller and they stand by their products (Pleade note that: I don’t work for them or get any rewards from them).
    It’s very important to note that if you don’t follow the manufacturer’s brake-in steps, it doesn’t matter how good the brakes are or how expensive they are, they will warp!!
    https://www.carid.com/2017-toyota-tundra-brakes/ebc-stage-5-superstreet-brake-kit-468976173.html?parentsubmodel[]=SUBMODEL|SR5
  20. Aug 4, 2018 at 9:51 PM
    ttc06
    Missouri
    yes, they turned all four under warranty.
  21. Aug 4, 2018 at 10:21 PM
    ttc06
    Missouri
    this is the service ticket. they resurfaced them. i wish i had known about the tsb.
    BTBAKER and trdprobped17 like this.
  22. Aug 4, 2018 at 10:25 PM
    Fired
    Fired Flame Extinguishment Specialist - Ret.
    The LowCountry
    '18 Limited Dbl Cab TRDOR
    Swapped 5.7 for V6
    Stance Looks Great! Always liked a little factory rake to a lift :thumbsup:
    HighDesertSurfer likes this.
  23. Aug 4, 2018 at 10:26 PM
    ttc06
    Missouri
    thanks. i love having a slight rake still.
  24. Aug 4, 2018 at 10:30 PM
    ttc06
    Missouri
    it doesn't say anything there about replacing rotors. i was told that toyota will do one resurfacing during the warranty period.
  25. Aug 4, 2018 at 10:33 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    Interesting, did they take your word for it, or did you have to pull a few teeth to get it done?
  26. Aug 4, 2018 at 10:39 PM
    ttc06
    Missouri
    told them i had vibration braking and they just did it. they did bullshit me when i asked how a 26000 mile truck had rotor issues. he said "it's a heavy truck and the brakes take a beating, and i may have run through a puddle when they were hot." i was there for 3 hours at that point so i just wanted to get out. for what it's worth the truck brakes perfect now. hopefully i won't have anymore issues, but i will probably get slotted or cross drilled rotors at some point
  27. Aug 5, 2018 at 5:16 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    They told you that is what the TSB entails? Resurfacing? I’ll find out on Tuesday. It would be the worlds WORST TSB. Have a TSB because of sub par part. Take part, grind it thinner and put back on. Now, wait for it fail even sooner!
    Skippy and Pudge like this.
  28. Aug 5, 2018 at 7:54 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    This confuses me a little.
    The warped rotors are a what, maybe 10-15% market issue?
    Service bulliten is a repair, not a recall. Resurfacing the rotors is in fact that - a repair not charged to the consumer.
    They could very well have just said pound sand.
    That least thats just my opinion.
  29. Aug 5, 2018 at 10:51 AM
    Tundra101
    Tundra101 New Member
    ODee
    Upstate NY
    2017 Quicksand Tundra SR5 4X4
    Pro Comp 6” Lift
    How about a Brembo Brakes setup?
    Cheap too ;)
    https://www.carid.com/2017-toyota-t...ourSubModelName][]=SR5&manufacturers[]=Brembo
    BTBAKER likes this.
  30. Aug 5, 2018 at 12:49 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I disagree. They issue a recall because the issue could be safety oriented and they don’t want to get the shit sued out of them. A TSB basically says we know there is an issue but it falls short of the recall standards which by the way is also a “repair”.
    If they take the TSB and put a rotor better designed to not warp under normal use and towing what they have determined the truck to pull it’s still a “repair.”
    Now if resurfacing and inferior part is the answer then it’s basically just a short term solution because it will no doubt happen again.
    If that’s the solution to mine then I will be looking aftermarket and spending 600-1000 bucks on a 50,000 dollar truck with 15,000 miles on it. That is unacceptable and a FAILURE on Toyota’s part to match the brakes to the truck.
    14burrito[QUOTED] likes this.
