Pro Grill insert
Discussion in '2.5 Gen Tundras (2014-2021)' started by Worriedman50, Jan 5, 2020.
  1. Jan 5, 2020 at 6:55 PM
    Worriedman50
    Worriedman50 [OP] New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    I have picked up a used Pro Grill in Super White, but there is a hole in the middle under that TOYOTA that evidently is a take-out piece of some kind.
    Can a person order a replacement?
  2. Jan 5, 2020 at 7:09 PM
    Blueknights75
    Ron
    Clayton, NC
    I am assuming this is a newer version PRO grill, if so you should be able to get a cover for that hole.... @Roman should be able to assist you with a PN.
    Roman likes this.
  3. Jan 5, 2020 at 7:55 PM
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    There’s a sensor cover that goes there. OEM is crazy expensive, more than the grill. But there is aftermarket and eBay clones since you don’t need it to actually work I’d go that route.
  4. Jan 5, 2020 at 8:01 PM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    Since you do not have a 2018+ Tundra with the radar sensor, you don't need the $300 OEM Toyota cover for that spot. You can buy a cheap knock-off from eBay for $30-$60.
    Here's one: https://www.ebay.com/itm/53141-3401...ensor-Cover-For-2018-2019-Tundra/193215923269
    Or Ares makes a textured one that is also nice and works with the radar sensor (not that you need it). Go to Ares Customs dot com and click on Auto.
    phogallen and TundraDude18 like this.
  5. Jan 6, 2020 at 6:07 PM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Thanks, got it!
