Pro comp stage 1
Discussion in 'Suspension' started by Tundra_mike89, Aug 4, 2017.
  1. Aug 4, 2017 at 8:28 AM
    Tundra_mike89
    Tundra_mike89 [OP] New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    pro comp stage 1 6" lift kit. I see it uses spacers in the front. Is this kit any good?
    GNTundra and Jsena like this.
  2. Aug 4, 2017 at 8:33 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yes it's a good kit, my opinion the top 3 kits out there are Ready Lift, Pro comp, BDS.
  3. Aug 4, 2017 at 8:36 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Do you have one installed? And how is the ride?
    GNTundra and Jsena[QUOTED] like this.
  4. Aug 4, 2017 at 8:49 AM
    Spacer kit... no bueno rough ride jus for looks no serious off roading check out toytec.com Boss kit...came into lifted scene blind truck i bought came with 6" lift spacers front blocks rear feel every bump on road remember this is my OPINION others on here can say diff... Also how you gona use your ride street queen or serious off roading...i say do some good research before diving in n spending hard earned money good luck
    GNTundra, Law323 and Jsena like this.
  5. Aug 4, 2017 at 8:54 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Pay the little extra and get the stage 2. I like mine. Comes with coilovers. Then get toytec shackles and you'll be good to go. Then save up and get a leaf pack and replace the rear blocks
    GNTundra, Bear, Law323 and 1 other person like this.
  6. Aug 4, 2017 at 9:07 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea I have the 7 inch BDS kit installed.. I don't off road. Strictly street Truck and it feels fine to me. I have MT tires also so remember one thing. If you're going from a stock truck to a lifted truck, lots of things change. Tires are gonna make the ride diff also.. with that being said. My lift feels great. I ride only street, I know it's not gonna ride as smooth as stock. That's what you need to know.. the spacer lift that you hear people talk about. I don't have any issues with mine.. it rides good, freeway feels good.. I might get the Coilovers added to mine next year but it's not a must for me. Mine rides fine. The brand of lift you get also determines the quality of the ride. There are others that are better.. you can do research and see which ones are good and the ones you should stay away from. Check out people's build pages and see what they have done to their trucks.. gives you a good idea of where to start and options you have..
    GNTundra and Law323 like this.
  7. Aug 4, 2017 at 9:16 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
  8. Aug 4, 2017 at 9:22 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Not to thread jack but what is a leaf kit that can be used to eliminate the 3in block and AAL that come with the procomp kit? Currently I'm running that setup with toytec shackles at 1 1/2 to get my truck to sit level
    GNTundra, Jsena and Hattori[QUOTED] like this.
  9. Aug 4, 2017 at 9:26 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    i'd say coilovers are superior to spacers. Personally, I would go stage 2 or above. I had a spacer lift (3/1) before I wised up and got my coilovers. Big difference, of course, I live in a city where potholes, broken shocks and shitty road maintenance is an everyday thing. Plus I do go down pretty nice trails on the way to the cabin and fishing spots......
    GNTundra, Jsena and Hattori like this.
  10. Aug 4, 2017 at 9:26 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I've done em with Skyjacker Part# TUR47S. No block needed and you can use your desired shackle size. Rides A HELLUVA LOT nicer. Check em out
    https://skyjacker.com/shop/suspension-lift-kit/tu761pks-n/#rear-leaf-spring-included
    GNTundra, Jsena and Law323 like this.
  11. Aug 4, 2017 at 10:12 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Is there something around a 4in? I think I'd be sitting too high in the ass with that leaf kit. Says it's 6 in. I figured to replace the block and the AAL would be around 4 in. Or am I wrong assuming that? Like I said I'm sitting level maybe just a bit high in the rear with 3in block, AAL from procomp and toytec shackles set at 1 1/2
    GNTundra likes this.
  12. Aug 4, 2017 at 10:15 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Or is that saying these are the leaf kits to use with a 6in lift?
  13. Aug 4, 2017 at 10:32 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Its good amongst its peers. That said, no spacer lift is optimal. Consider Bilstein 5100s
  14. Aug 4, 2017 at 10:38 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I ordered the toytec boss kit but considering selling it and going pro comp 6" spacer kit?
  15. Aug 4, 2017 at 10:49 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
  16. Aug 4, 2017 at 10:51 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    He's looking for 6 inch
  17. Aug 4, 2017 at 10:53 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
  18. Aug 4, 2017 at 11:31 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
  19. Aug 4, 2017 at 11:37 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    If you want to sell me the Boss kit, sure! :devil:
    Law323 likes this.
  20. Aug 4, 2017 at 11:38 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I'm getting it tomorrow. If it looks good I'll keep it. If not I'll sell it for 150 bucks cheaper than what I got it for.
  21. Aug 4, 2017 at 11:45 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Are you mall crawling or do you off road
  22. Aug 4, 2017 at 11:50 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Off road. Sometimes I need 4x4 to get to my house. BUT my wife and I drive across Texas quite a bit in my truck
  23. Aug 4, 2017 at 11:55 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    definitely stay away from spacers. Go the stage 2 or up.
    GNTundra and Dustydirt19 like this.
  24. Aug 4, 2017 at 11:55 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    can I jump my truck with the boss kit??
  25. Aug 4, 2017 at 11:56 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    LOL i'd say you need bypasses and good bump stops for that.
    you for damn sure couldn't jump with the stage one!
    ask @Hattori He's building up his tundra for jumps and all kinds of 4x4 shennanigans!
    GNTundra, Dustydirt19 and Jsena like this.
  26. Aug 4, 2017 at 12:11 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    What size tires you thinking about running?
  27. Aug 4, 2017 at 12:40 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    And mine is 2wd:wink:
    OP, you can jump it but you might not like the outcome......:tumbleweed:
  28. Aug 4, 2017 at 12:53 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    :devil::devil::devil::devil::devil::devil::devil:
    you know your truck's badass when it can do more than a 4wd! LOL
    GNTundra and Hattori[QUOTED] like this.
  29. Aug 4, 2017 at 1:29 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Or WILLING to do more than most 4wd!!
    GNTundra and Law323[QUOTED] like this.
  30. Aug 4, 2017 at 2:26 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Even better!! :bowdown::bowdown::bowdown::bowdown:
