Pro Comp 41 Phaser Rims
Discussion in 'Wheels & Tires' started by AJGallo41, Nov 20, 2021.
  1. Nov 20, 2021 at 9:52 AM
    AJGallo41
    AJGallo41 [OP] New Member
    Aj
    MN
    2016 Tundra Crewmax 5.7
    Level Kit 275/70r18 BFG KO2's
    Hello,
    I just bought a set of used Pro Comp Phaser 41 rims for my truck but they didn’t come with center caps, does anyone know where I could find the center caps for these? Or if there’s universal ones I could get? Are all of pro comps center caps compatible? Any help would be appreciated.
  2. Nov 20, 2021 at 9:57 AM
    2mchfun
    Check the Center cap store website.
    AJGallo41[OP] likes this.
  3. Nov 20, 2021 at 10:00 AM
    AJGallo41
    Aj
    MN
    Didnt even know there was one! Thank you, I’ll check
    2mchfun[QUOTED] likes this.
  4. Nov 20, 2021 at 10:05 AM
    2mchfun
    Might try Ebay as well.
  5. Nov 20, 2021 at 10:08 AM
    AJGallo41
    Aj
    MN
    Problem I’m having is I don’t have a current center cap so I can’t check if the part number is correct
  6. Nov 20, 2021 at 10:18 AM
    2mchfun
    Research and research some more, or contact pro comp directly. Might try 4wheel parts or tire rack.com.
  7. Nov 20, 2021 at 10:29 AM
    seniao
    seniao New Member
    Santi
    Buford, GA
    2019 Silver Sky Metallic SR5 Double Cab
    TRD Pro Head Lamps Spray Bed Liner Side steps Peragon Tonneau cover
    2mchfun and AJGallo41[OP] like this.
  8. Nov 20, 2021 at 10:35 AM
    AJGallo41
    Aj
    MN
    2mchfun likes this.
