Pro comp 3/1 leveling kit installation cost question?
Discussion in 'New Member Introductions' started by Homewood, Mar 17, 2016.
  1. Mar 17, 2016 at 9:33 PM
    Homewood
    Homewood [OP] New Member
    2008 sr5 double door srd 4x4
    I have a 2008 SR5 Trd dbl door 4x4. My local tire shop wants $650 to install the leveling kit which includes the cost of the kit. They said it would take three hours to install. Is this right?
    Thanks for any advice!
  2. Mar 18, 2016 at 2:28 PM
    poto-toyo
    poto-toyo New Member
    Houston, Tx
    2012 Tundra Crewmax
    3-1 level 305/55/20 w/Pro-comp, Stubby Antenna, tow mirrors
    My 3-1 Pro comp level w/install cost $627 tax included. Pro comp products kinda have a bad rep on the site, but so far no complaints here. fYI I don't off road, strictly for looks. Good luck and welcome to the site.
  3. Mar 18, 2016 at 3:18 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yea i don't have experience with Pro-comp myself but seared away from it in the past because its known as procrap on the forums.
    I have heard the pro runner is a copy of the Bilstein 5100. If its truly a copy it should be similar in ride.
    Based on the price i am assuming that it is just a spacer lift though without new shocks. Looks like spacer lifts are around $300 so that would put the install around $350. I think we have said on here that these lifts should cost around $300 installed. Not far off from norm then.
  4. Mar 18, 2016 at 3:27 PM
    csuviper
    Broomfield, CO
    There are two types of spacer lifts; Above coil and In-coil. Each have their pros and cons. The problem that people see with spacer lifts is that it can cause shock failure. Either in the droop position or compressed position.
    One thing i found interesting is that Toytec has a split spacer design. They add part of the lift above the coil and part of the lift in the coil. I assume to alleviate the possible shock problems.
    http://toyteclifts.3dcartstores.com/BEST-SELLER-3-Lift-for-07-UP-Tundra_p_377.html
  5. Mar 18, 2016 at 7:01 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    3 hours sounds like no fab work, could prob do it in you garage in an afternoon
