Prinsu rack.
Discussion in '1st Gen Tundras (2000-2006)' started by NWTundra06, Feb 12, 2021.
  1. Feb 12, 2021 at 1:29 PM
    NWTundra06
    NWTundra06 [OP] New Member
    06 Tundra AC TRD
    FirstGenVol likes this.
  2. Feb 12, 2021 at 1:36 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I wonder how the added wind noise effects sound level in the cab.
    Voss likes this.
  3. Feb 12, 2021 at 2:14 PM
    Sunnier
    Sunny
    San Diego, CA
    Everything I read says “it depends on the weather” when it comes to warnings about rust. But I live inland San Diego county (away from salt air and most precipitation) and, every single roof rack I’ve looked at had rust on the roof where the metal rack attaches. I’m sure there are ways to prevent it with diligent care... but I recognize that I am not really going to do those things as consistently as would be required, so I’m rocking an Inno rack. Probably a lot like your current Yakima setup.
  4. Feb 12, 2021 at 5:30 PM
    Kcrusher62
    Kcrusher62 New Member
    I installed this rack on my truck about a month ago. Total honesty, really unnerving drilling holes into the roof,watched the install video like a dozen times lol.I used 3M marine sealant and adhesive 5200 on plus nuts. Live in AZ so hoping rust will not be much of an issue. Rack and hardware are really nice quality as should be considering price point. I did install the noise/wind deflector so have not noticed any increase in wind noise. Hope this helps.
    NWTundra06[OP] and FirstGenVol like this.
  5. Feb 12, 2021 at 5:54 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you already have a Yakima setup why not have a custom rack built for it? I bet thats less than $700 and you can forget about drilling.
    des2mtn and Sunnier like this.
  6. Feb 12, 2021 at 7:23 PM
    NWTundra06
    06 Tundra AC TRD
    I definitely get wind noise with my Yakima towers. And some water drips in a hard rain, I expect because the rubber seal is pressed in to secure the feet
    onesojourner[QUOTED] likes this.
  7. Feb 12, 2021 at 7:29 PM
    NWTundra06
    06 Tundra AC TRD
    Hadn't thought of that. I was thinking that with the bolt on rack, I would be able to mount a rooftop tent. I suppose for my needs a ladder rack might be better suited.
  8. Feb 12, 2021 at 7:47 PM
    Sunnier
    Sunny
    San Diego, CA
    The problem with a roof top tent mounted on the roof is dynamic weight. Even the lightest tents that are within parameters when you’re not moving, weigh too much when adjusted for “dynamic”, i.e. the truck traveling at speed, with air forces into it, etc.
    des2mtn and Darkness like this.
  9. Feb 12, 2021 at 7:49 PM
    Sunnier
    Sunny
    San Diego, CA
    A better option, weight and stability-wise, maybe to add a bedrack-?
  10. Feb 12, 2021 at 8:05 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Butyl tape will help to prevent the rust and will act as a sealant as well just FYI
    Sunnier and Rica25 like this.
  11. Feb 15, 2021 at 6:40 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This makes me curious. How exactly do the Yakima bars mount without drilling? There is nothing up there to grab onto other than those drip channels.
  12. Feb 15, 2021 at 10:27 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I imagine the front part grabs under the door, for the rear part I'm not sure on an access cab.
  13. Feb 15, 2021 at 11:14 AM
    Sunnier
    Sunny
    San Diego, CA
    I imagine it is like the Inno racks I have mounted on Hulk (which were like the Thule racks I had on another car). A not-thick metal tab fits below/outside the weatherstrip along the lower edge of the roof to reach inside the truck but doesn’t interfere with doors closing. The locking part of the bar attachment that sits atop the roof clamps the outside. One clamps along the front door, another clamps along the rear “access” door. The weatherstrip on the jamb and doors will likely require replacing at some point but, so far, doesn’t allow wind noise, the doors shut tightly, no problems.
    Hulk is at an orthopedic appointment :rolleyes:
    (getting a knee rebuilt by Dr. Rice) but I’ll post pics when I can.
  14. Feb 15, 2021 at 11:19 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Be sure to sign him up for physical therapy after :curls:
    Sunnier[QUOTED] likes this.
  15. Feb 15, 2021 at 11:29 AM
    Sunnier
    Sunny
    San Diego, CA
    Definitely!
    Ha! Actually, first he’ll need a “chiropractic” appointment. ;)
    Darkness[QUOTED] likes this.
  16. Feb 25, 2021 at 5:55 PM
    rattail00
    rattail00 New Member
    Northwestern WA
    2017 Toyota Tundra SR5 Crewmax
    Can someone with a Prinsu rack measure the distance between your mounting holes for the roof rack? I'm getting a roof rack made and me and the fabricator would like to try to mount in the same location as the prinsu racks to be safe. With the curve in the rain gutters it makes it tough to figure out where to go from.
  17. Feb 25, 2021 at 6:25 PM
    Sunnier
    Sunny
    San Diego, CA
    There’s no ‘safe’. I hear you, and think it’s great you’re asking for this info from others. But the only way to ensure you don’t drill into airbags will be to remove the headliner. Victory taught us all this.
  18. Feb 25, 2021 at 6:27 PM
    rattail00
    Northwestern WA
    Yeah I understand that, I meant safe meaning we get the distance the first time. I'm working with a fabricator that is out of state so I just wanted to make sure I get the measurements right. I also just noticed this is a first gen post, I'm a 2017. Sorry y'all!
    Sunnier likes this.
  19. Feb 25, 2021 at 6:29 PM
    Sunnier
    Sunny
    San Diego, CA
    No problem. Cool you figured it out.
