Pressurized Waterport/water tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mrf1987, Jul 10, 2022.
  1. Jul 10, 2022 at 6:53 PM
    Mrf1987
    Mrf1987 [OP] New Member
    2020 Trd sport tundra
    Thought maybe some of you would like to see this setup I put together today. Great setup to use to pressurize all water tanks.
    Built a pressure setup to keep the @thewaterport weekender supplied with 35psi constantly from the @arb4x4usa dual compressor. This is a game changer when out for days with no way to run a hose to fill the waterport back up. Just add more water and hit the switch on the @switch.pros.official and the 12v solenoid off the arb compressor let’s air go to the tank!
    Here is what I used to complete the task. “All parts from Amazon
    you will need to pick up some 1/4” brass fittings to adapt from your air source to the push lock fittings. The scrader valve that comes on the waterport is 1/8” npt and because I did not have a 1/8”npt x 1/4 push lock I made my own adapter out of brass.
    *https://www.amazon.com/Pneumatic-Connect-Fittings-Nickel-Plated-Connectors/dp/B07HJ4JSV8?pd_rd_w=s0pEK&content-id=amzn1.sym.94349326-ca8a-4b0d-94f0-6931485b8573&pf_rd_p=94349326-ca8a-4b0d-94f0-6931485b8573&pf_rd_r=HRT88H6ZEHFJX2CSDDZT&pd_rd_wg=C1iNd&pd_rd_r=98d07d13-2cbf-4c56-a572-f1bfc654427c&pd_rd_i=B07HJ4JSV8&ref_=pd_bap_m_rp_1_i
    https://www.amazon.com/4inch-Normal...4427c&pd_rd_i=B074Z5SDG3&ref_=pd_bap_m_rp_2_t
    https://www.amazon.com/Control-Devi...4427c&pd_rd_i=B007GDXA60&ref_=pd_bap_m_rp_3_t
    https://www.amazon.com/gp/aw/d/B00IDCYKEY?ref=ppx_pop_mob_b_asin_title
    https://www.amazon.com/gp/aw/d/B074KD1DCH?ref=ppx_pop_mob_b_asin_title
    https://www.amazon.com/PneumaticPlu...fix=1/4+x1/8+pushlock+fitting+,aps,182&sr=8-5
    TampaRD Pro, Jeff_1974, Mater and 5 others like this.
  2. Jul 14, 2022 at 7:24 AM
    Foxtrot704
    Foxtrot704 New Member
    Daniel
    2020 Silver Metallic Tundra SR5
    FOX 2.0 leveling coilovers and rear shocks, ARB twin compressor, Victory 4x4 roof rack and rock sliders
    Nice setup. I was thinking of doing something similar on my roof rack. How did you route the airline from under the hood to the roof?
    Mrf1987[OP] likes this.
  3. Jul 14, 2022 at 7:46 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Excellent work!
  4. Jul 14, 2022 at 8:18 AM
    Mrf1987
    thanks man! I ran it down the passenger inner fender and along the frame rail then up between the cab and camper shell. I secured the line with 3m adhesion zip tie mounts. The mounts stick on and bolt the air line perfect.
  5. Jul 14, 2022 at 11:29 AM
    Foxtrot704
    Daniel
    Good deal. I just noticed the air solenoid. What is that for?
    Mrf1987[QUOTED][OP] likes this.
  6. Jul 14, 2022 at 11:32 AM
    Mrf1987
    The air pressure regulator on the roof keeps me from over pressuring the waterport tank. I set it at 30psi. The solenoid on the front off the arb compressor allows me to control when air goes to the waterport from my compressor. I wired the solenoid into my switch pros.
  7. Jul 14, 2022 at 11:47 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    Whats the info on that fuse block tray?
  8. Jul 14, 2022 at 11:55 AM
    Foxtrot704
    Daniel
    Nice. Thats a pretty smart setup. This is my current setup with my day tank. But now that I have the roof rack I'd like something bigger and more permanent like what you have. Thanks for the info!
  9. Jul 14, 2022 at 12:09 PM
    Mrf1987
    I had about the same setup with my daytank but it got old having it in the back of my tundra. The roof mount is so much better especially for showers etc
    Foxtrot704[QUOTED] likes this.
  10. Jul 14, 2022 at 12:09 PM
    Mrf1987
    It is a @sdoffroadmt on ig. Guys name is Derek and he makes bad ass products give him a shout
