Preferred Oil
Discussion in 'General Tundra Discussion' started by Kenmills, Aug 9, 2025.
  1. Aug 9, 2025 at 7:42 AM
    Kenmills
    Kenmills [OP] New Member
    Ken
    2019 SR Long Bed
    I'm curious of what engine oil everyone prefers. Is the 0w20 what you use, has anyone used a heavier weight and what results did you get?
  2. Aug 9, 2025 at 7:48 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Most of us use 5-30 for a host of reasons - just do a search. Which type would be Full Synthetic and the brand could be any of many. My fav is M1 in a high mileage 20K life variety - although I do 4K OCIs cuz that is what my 5.7 achieves in 1 year. Luck all.
    Mdl, PKFan and Kenmills[OP] like this.
  3. Aug 9, 2025 at 7:55 AM
    Kenmills
    Ken
    2019 SR Long Bed
    Thank you
  4. Aug 9, 2025 at 8:10 AM
    2mchfun
    mobil 1 5-30 FS
    AZBoatHauler and Kenmills[OP] like this.
  5. Aug 9, 2025 at 9:45 AM
    seydou
    seydou Distinguished Member
    I wait for a sale on the Kirkland and then buy a few boxes.
    Kenmills[OP] likes this.
  6. Aug 9, 2025 at 4:34 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Maybe I'm partial only because my dealer is a supplier, but I've been using this since 2006
  7. Aug 9, 2025 at 6:01 PM
    Kenmills
    Ken
    2019 SR Long Bed
    Have you noticed any decreased gas mileage with the heavier weight oil? How many miles does yours have?
  8. Aug 9, 2025 at 6:03 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    lol
    Anything 0w should be poured down the drain where it belongs
  9. Aug 9, 2025 at 6:16 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    5w-30, Pennzoil Ultra Platinum, FS. You'll have a happier engine with a heavier weight oil. I believe, and someone correct me if I'm wrong, GM is now passively recommending a heavier oil than 0w-20 to help correct their engine problems.
    Mdl and Kenmills[OP] like this.
  10. Aug 9, 2025 at 6:20 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :rofl:How did I miss an oil thread :angrygirl:
    Kirkland 5-30 in everything for the past 10 yrs
    WILLINH and Kenmills[OP] like this.
  11. Aug 12, 2025 at 12:32 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Toyota calls for 5w30 in my 5VZ and she has 317k
  12. Aug 12, 2025 at 12:43 PM
    Kenmills
    Ken
    2019 SR Long Bed
    Wow. Well alright.
  13. Aug 12, 2025 at 12:49 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    I ran 10w 30 summer time and 5w30 winter time once my truck got 200000 helped with the timing chain noise for me. I also ran 2 oz of sea foam per quart of oil in the motor and did the top end treat ment, and 1 can in the gas tank every 100000 miles after I did that I changed spark plugs and pvc valve. Made 365000 miles truck still ran great just when it let a head gasket go at about 363000 cost to repair a truck with that many miles was not effective for me with what I drove it all over America. No need for new engine with same drive Train. But that was just me. . Let her go at 365xxx. Miss that truck every day.
  14. Aug 12, 2025 at 1:00 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Valvoline restore and protect 5w-30, I had the timing chain noise at start up on my 2016 at 140,000 miles. After two oil changes, it made a noticeable difference on the noise, much quieter
  15. Aug 12, 2025 at 1:59 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    10W-30
    Less noise
    MPG basically the same because you can't really get much worse or better MPG from oil choice on this engine
    Barely ever freezes here so I don't have to worry about a super cold start
    0-20 is for the birds IMO
    '21 5.7 with 30K
  16. Aug 12, 2025 at 2:35 PM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    0w20 mobil1 full synthetic
  17. Aug 12, 2025 at 5:15 PM
    MEWaters
    MEWaters New Member
    Maine
    Dafuq
  18. Aug 12, 2025 at 5:45 PM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    I think he meant full synthetic
    EmergencyMaximum likes this.
  19. Aug 15, 2025 at 11:55 AM
    jake_sully_92
    jake_sully_92 New Member
    Yesterday
    Jake
    2011 Toyota Tundra 4.6L SR5 TRD 4X4
    I haven't done any of these myself: She has the TRD package from 2011. Bilstein Shocks from factory. Aftermarket intake, all else is cosmetic.
    I wish I had joined last night, I just had my oil changed....0W-20 full synthetic in. Welp, now I know. I've never changed the oil myself because of lack of space (weak excuse?) at our apartment but I might have to start just so I can use 5W-30. We have a 2011 Tundy with 178k on her, valve gasket leak, and cam tower leak, neither of which is bad; I check oil a few times a week.
    2mchfun and Leo's first like this.
  20. Aug 15, 2025 at 12:28 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    0 or 5w30, whatever full synthetic is on sale
  21. Aug 15, 2025 at 8:27 PM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    5w-30 whatever brand suits my fancy that change and between 5 - 10k miles.
    :deadhorse:
