Pre wired Camera by Toyota - 08 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Les7311, Jan 15, 2017.
  1. Jan 15, 2017 at 2:26 PM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Need your help fella tundrans.
    Thinking to install back up camera on 08 tundra and studying the YouTube link below.
    Dirty pic is yours truly, clean pic is from a screen shot from youtube.
    Does the 08 comes pre wired for a back up camera? These plug connectors looks identical.
    What's your thought?
    https://youtu.be/oFtlF95zE24
  2. Jan 17, 2017 at 4:44 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    A lot of them do come pre wired for the camera. That looks like the correct plug
    The plug is kind of towards the passenger side of the truck pined to the under bed rail area and you have to remove I think 6 screws from the over head consol to expose the wire harness tucked up in the headliner. Hope that helps
    I just installed mine a couple of weeks ago was pretty easy
  3. Feb 10, 2017 at 8:20 AM
    Les7311
    Hey "TheyFZman" where did you get your kit from? Am looking for the kit since am pre-wired....
  4. Feb 10, 2017 at 8:35 AM
    Theyfzman
    Pa
    08 TRD
    Off ebay here is the item number 152017828255 of the one I got but it should take you to another auction for one the user name is cooper_z71 if that doesn't work just do a search for reverse camera toyo tundra I paid $390 for the complete kit brand new
    Les7311[OP] likes this.
  5. Feb 10, 2017 at 8:36 AM
    Les7311
    Boombastic and about to check... is it all plug and play into the prewiring? I did find it on Ebay.....seems like its a go.....more difficult to park now that I have the 6 inch lift kit installed.
  6. Feb 10, 2017 at 8:44 AM
    Theyfzman
    Pa
    08 TRD
    Yup hardest part was fishing the wire through the tailgate lol easy plug and play the overhead console is a bit tricky some of the screws are hidden you have to pop off the map light covers to get to them there torx screws take the rearward ones off first then work forward the console kinda drops down in the back then slides out towards the rear it has 2 prongs in the front that need to be slid out then just reverse the process
    the plug is towards the driver side up inside the head liner
  7. Feb 10, 2017 at 9:01 AM
    Les7311
    Respeck! I guess if I run into any difficulties, I will just stop by you in PA while enroute to some fam if Morton...... teee heee....
  8. Feb 10, 2017 at 9:18 AM
    TheBeast The Beach
    good stuff
  9. Feb 10, 2017 at 10:11 AM
    Theyfzman
    Pa
    08 TRD
    No prob Im just north of Pittsburgh lol
  10. Feb 10, 2017 at 2:06 PM
    Les7311
    One more question. Does the head liner separate from the windshield after the console is removed, or you had to fish through also?
  11. Feb 10, 2017 at 2:10 PM
    Theyfzman
    Pa
    08 TRD
    You can just fish the wire in between the headliner and the roof, there is even the cover that covers the wire that you kind of wedge between the mirror anchor button and the headliner so you don't see the wires once your all done fishing it through it is, pretty easy mirror is held on with a torx screw as well
  12. Feb 10, 2017 at 2:28 PM
    Les7311
    Two thumbs up! Online making order. Will post update as soon as the brown truck arrives.
    NewImprovedRon likes this.
  13. Feb 21, 2017 at 12:53 PM
    Les7311
    The brown van showed up today. How much time should I put aside to do this surgery?
  14. Feb 21, 2017 at 4:16 PM
    Theyfzman
    Pa
    08 TRD
    I would say maybe an hour to an hour and a half hi don't need to rake the tailgate of just an FYI
  15. Feb 21, 2017 at 4:22 PM
    Les7311
    Ok. Am a bit under the weather and had planned on driving toy(undra) to work tomorrow.
    I watched the YouTube video a few times and wanted to tackle the easier side first ( uncertain which one is).
    Always appreciate your feedback.
    Will postpone.
  16. Feb 22, 2017 at 1:54 PM
    Les7311
    Happy like a parking-tamale. Installed camera and video all Within 90 minutes. Easy
