Pre-install check
Discussion in 'Audio & Video' started by Kung, Apr 22, 2020.
  1. Apr 22, 2020 at 11:16 AM
    Kung
    Kung [OP] [Insert Custom Title Here]
    KG, VA
    OK, so I've got the following equipment sitting in our closet waiting on next Monday's install:
    - JBL Stadium 5 amp
    - 10" subwoofer enclosure (from Tech12Volts)
    - Kicker CompRT 10" 2 Ohm Sub
    - Axxess AX-MLOC740 4-channel LOC
    - Scosche X2 amp high-current install kit
    Plan is to replace factory amp with aftermarket, using the LOC from Tech12Volts to keep it PNP; and then have the sub/enclosure installed. I'll likely have them at least install some sound deadener at the same time.
    Anything else I'm missing for now? I was going to wait about a month before installing aftermarket speakers.
  2. Apr 22, 2020 at 11:19 AM
    Kung
    KG, VA
    Additionally - plan is to keep the stock head unit long term; if this is the case, I'm assuming I'll want a DSP of some sort, correct?
  3. Apr 22, 2020 at 6:09 PM
    Twinky
    07 double cab work horse
    There's been a couple different variants through out the year, but the chances are that you'll need a dsp that can take a digital signal as an input.
    If that is the case, then James at tech12volts sells a nice one that he is also able to pre setup to work with your truck.
  4. Apr 22, 2020 at 6:15 PM
    Kung
    KG, VA
    That's what I'm thinking, though (I believe) the install date will be here before I could get a DSP. I assume this is something I could have connected later....?
  5. Apr 22, 2020 at 6:20 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Is your stock system jbl or not that will determine your have to haves
  6. Apr 22, 2020 at 6:21 PM
    ToyoMafia
    Magic carpet.
    A dsp is optional in a non jbl system. I do not have one on my truck.
  7. Apr 22, 2020 at 6:48 PM
    Kung
    KG, VA
    It's a non-JBL system for sure. :)
  8. Apr 22, 2020 at 6:52 PM
    ToyoMafia
    Magic carpet.
    Let’s ask James at @tech12volt just to be sure. I’m not 100% on the 2020
  9. Apr 22, 2020 at 7:15 PM
    Kung
    KG, VA
    Done - I'll post his response here when I get it.
  10. Apr 22, 2020 at 7:49 PM
    ToyoMafia
    Magic carpet.
    If you hit him threw the forum it might take a few. If you send him a direct email you will get a response fast. Pm me if you need his email
  11. Apr 22, 2020 at 9:13 PM
    Kung
    KG, VA
    His response:
    LOL - well then, I'm good to go. (Full disclosure; am an IT guy and was an ET in the Navy, so I'm quite sure I could figure out what to do with it, but hey, if it's not needed, I won't bother spending the $ on it then. :)
  12. Apr 22, 2020 at 9:37 PM
    You can also do the sound deadening yourself. It’s not too difficult- at least doing the door panels it wasn’t.
    Twinky likes this.
  13. Apr 23, 2020 at 6:09 AM
    Kung
    KG, VA
    Well yeah, I should have clarified that since they'll already have the seats out to install the sub/enclosure, it shouldn't be too much more to add some sound deadener back there. I can do the doors on my own when I decide to upgrade the door speakers.
  14. Apr 28, 2020 at 8:16 AM
    Kung
    KG, VA
    Ok, so the install was done, and it sounds fantastic, I might say - at least sort of. LOL The quality of the bass is far better, obviously. However, there wasn't that much in the way of mids/trebles to begin with...and now that there's more bass, obviously it's kind of drowning out the mids/trebles.
    Some of that can be ameliorated (heh, my big word for the day) by doing some tweaking to the 5-channel amp that was installed, of course, but ultimately I'll need to install some aftermarket speakers. Tech12Volts recommends the K170 group buy with sail panels. For those who have this, what do you think of them? Satisfied overall? Not that I doubt at all James' recommendations, but real-world experiences are always nice to hear. :)
