PRE- BLACK FRIDAY SALE
Discussion in 'General Tundra Discussion' started by ragofabrication, Nov 20, 2019.
  1. Nov 20, 2019 at 11:14 AM
    ragofabrication
    ragofabrication [OP] New Member
    Melissa Rago
    Pre-Black Friday deals will be ending on Sunday. There will be DIFFERENT sales for Black Friday so don't delay on these great deals.
    STAINLESS STEEL DIFFERENCE
    Stronger than steel
    Nonmagnetic
    Will not corrode or rust
    Lifetime RUST FREE GUARANTEE
    Made in the USA
    No Drilling Required
    Stainless Steel Hardware
    Billet Aluminum Stand-Offs
    Stainless Steel Bottle Opener
    Raw Steel*
    Laser Cut and CNC Bent 1/8" Cold Rolled Steel
    Hand Sanded to Ensure a Even Surface
    Shape Conforms to the Window and Shape of the Body
    Designed by Rago Fabrication - Veteran Family Owned Business
    3 Mounting Locations - Including a Wide Platform to ensure strength and reduce rattle.
    The Rago Fabrication Shock Guards were designed to keep your shocks safe and free of damage. The rugged angular design creates a guard that can withstand the most demanding trails. In addition to protecting the most exposed part of the shock, the guard also extends to protect the shock shaft from pits and abuse, extending shock life from leaks and tears of the shock shaft seal. Our design also includes a drain hole placed at the lowest point of the guard to prevent lingering of water during water crossings.
    American Made
    Completely bolt-on. No drilling required.
    Increase the longevity of your shocks with the Rago Fabrication shock guards.
    Material: 3/16th Steel powder coated black.
    King shock compatible.
    NOT COMPATIBLE WITH ICON RXT STYLE SHOCK
    The mounts are CAD designed, CNC cut, CNC bent, and welded by Rago Fabrication. They come with high torque knobs. Rago Fabrication designed and made the knobs in house with 1/2 inch bolts that are welded internally. They will never break away from over tightening like the plastic knobs are known for.
    Made in the USA
    Easy Installation
    No Trimming or Cutting of Bumper
    Fit Most 30-32" Single and Dual Row LED Bars
    Powder coated Textured Black
    Lifetime Warranty and the Rago Promise – Satisfaction Guarantee
    Patent Number: US D784, 114S
    Rago Fabrication has set a new standard in the rock slider market. These rock sliders feature a new design that hugs the frame 360 degrees while still being bolt on. The frame mounts are fully boxed made from 3/16th steel and could not get any beefier. We only use 1 3/4 .120 wall DOM tubing because we believe seam walled tubing, although sufficient, will not stand up to the extreme off-road environment. Our design is streamlined, low profile, and flows nicely with the factory body lines.
    Made in the USA
    CNC Cut 3/16 Stainless Steel
    No Drilling or Trimming Required
    Bolts on Hood Hinge
    Low Profile Clean Look
    Blemished: Powder coated Black Textured Black w/ Minor Powder Coating Imperfections
    Lifetime Warranty and the Rago Promise – Satisfaction Guaranteed
    WE ALWAYS HAVE THE BEST PRICE ON BAJA DESIGN LIGHTS!
    PM OR EMAIL INFO@RAGOFABRICATION.COM FOR PRICING​
