Powerstop Z36 brake kit, any good?
Discussion in '2.5 Gen Tundras (2014-2021)' started by GNX6, Apr 3, 2021.
  1. Apr 3, 2021 at 7:30 PM
    GNX6
    GNX6 [OP] New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    Currently I have TRD pads and high carbon steel rotors on my truck, they are ok but not awesome. Now I have an 8000LB trailer and I think the brakes are not up to the task. Anyone use the power stop or find something better?
  2. Apr 3, 2021 at 7:35 PM
    I had PowerStops and had heat marks with warping issues with them. That is common with slotted and drilled rotors. Drilled rotors are known for pulsating as well.. Now I have StopTech Sport. Cryo treated and slotted only. :thumbsup:
  3. Apr 3, 2021 at 7:50 PM
    GNX6
    2014 Crewmax
    Last set of drilled slotted I had on my 02 Monte SS pulsated like crazy bad on hard braking, even new. (I was a GM tech for 22 years so anyone that is gonna post did you install them right can save it :) ) Much prefer a solid rotor. I will have a look at those, thanks for the input.
  4. Apr 3, 2021 at 7:59 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Are you asking about the Z36 pads or the rotors as well? I'm contemplating those pads w/stock rotors.
  5. Apr 3, 2021 at 8:05 PM
    TJMoeller
    TJMoeller New Member
    Timothy
    Bel Air, Harford Co. MD
    2007 NBM Crewmax Limited
    K&N drop in, TRD Dual exhaust, TRD stubby antenna, Morimoto XB LED headlights XB LED foglights & SpyderTaillights, Toytec 2.5/1 lift, FN BFD 18x9 +18 in Matte Bronze
    ^^+1 for this set-up i just installed stoptech slotted only rotors with hawk LTS pads. Also I sprung for the stoptech stainless lines (6 total) 2 front 2 rear and 2 bed to axle. 1000 times better feel! less pedal travel and twice as firm in panic stops. highly recommend!
    Skew12 likes this.
  6. Apr 3, 2021 at 9:35 PM
    GNX6
    2014 Crewmax
    Well now that you mention it, pedal feel is pretty lousy on these....
  7. Apr 3, 2021 at 9:37 PM
    GNX6
    2014 Crewmax
    The kit with pads and rotors...
  8. Apr 3, 2021 at 10:22 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    I’ve got the z36 pads all around, carquest premium rotors on front and oem rotors on rear. They seem to work well.
  9. Apr 3, 2021 at 10:27 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have the stoptech slotted. Going back to oem and trd pads when these wear out. I have about 10k miles to go on them
    ColoradoTJ likes this.
  10. Apr 3, 2021 at 10:59 PM
  11. Apr 4, 2021 at 12:44 AM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    I would be looking at the brakes on the trailer if your concerned. The stock brakes are plenty good.
  12. Apr 4, 2021 at 1:53 AM
    Redcon41318
    Redcon41318 New Member
    8k trailer on a 1/2 ton truck. Consider road safety go with. 3/4ton. I have money youre over the limit on payload etc.
  13. Apr 4, 2021 at 4:20 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    OEMs are really good...I swapped to StopTech drilled/slotted rotors w/ Z36 and they don't stop as well as the OEM.
    Agree with Redcon...you probably need a 3/4 ton truck.
  14. Apr 6, 2021 at 8:02 PM
    Dansly56
    Dansly56 New Member
    daniel
    What’s the link to the ones you bought? I’m in the market for rotors and pads
  15. Apr 7, 2021 at 4:35 AM
    I got them from AutoAnything. I'll pull my order and get you the part numbers. Also, once you add them to the cart, do live chat with them and ask if cart items are the best price. They will usually give you another $20 to $30 dollars off.
    Dansly56[QUOTED] likes this.
  16. Apr 7, 2021 at 5:06 AM
    Here is a list of what I have.
  17. Apr 7, 2021 at 5:22 AM
    msmmce1
    msmmce1 New Member
    I have a 2015 Tundra and it has fantastic brakes with factory pads and rotors, 4 piston calipers and huge vented rotors front and rear. Not being able to adequately stop an 8000lb trailer is more a function of improperly adjusted or improperly functioning trailer brakes. Does your trailer have brakes on both axles?
  18. Apr 7, 2021 at 8:28 AM
    Dansly56
    Dansly56 New Member
    daniel
    Right on! Thanks!
    Tundra234[QUOTED] likes this.
  19. Apr 22, 2021 at 12:15 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I’ve been currently running the PowerStop rotors and Z36 pads and haven’t had any issues with the setup.
    I’ve definitely put a good amount of miles on them and can say that it does feel like I need to apply more pressure to slow down or stop
