Power Wire Fuse Holder Location
Discussion in 'Audio & Video' started by DSTundra, Jan 26, 2020.
  1. Jan 26, 2020 at 5:21 AM
    DSTundra
    DSTundra [OP] New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Got a question for the folks who have amp power wire running to the engine bay... What did you attach your fuse holder to?
    Dave
  2. Jan 26, 2020 at 6:13 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Driver side fender over fuse box. I never understood why people drill through the plastic fuse panel cover. Lol.
  3. Jan 26, 2020 at 6:39 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Fuse box above battery
  4. Jan 26, 2020 at 7:54 AM
    DSTundra
    Dave
    Albuquerque, NM
    Yeah, I was thinking about that, but apparently the fuse holder is supposed to be within 12" of the terminal connection. No way I can attach it there and be within 12". I'm not a fan of attaching to the plastic cover either. I saw on a 5 Star Car Stereo video of a Tundra install where they installed some sort of additional riser bracket to the left of the fuse box which provided a flat surface to mount the fuse holder. It was really cool and provided for a clean install, but I've searched and I've haven't seen one for sale. I guess it would probably help if I knew what it was called.
  5. Jan 26, 2020 at 8:25 AM
    Jrharvey02
    I understand your hesitation with the fuse box location, but many, many of us on here use that as it’s the only location within 12” for a fuse, it’s convenient among other things. If you’re worried about small hoes in the lid, use a dab of liquid electrical tape over the screw. You can also patch screw holes with it too.
    smslavin likes this.
  6. Jan 26, 2020 at 8:40 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I put mine here:
  7. Jan 26, 2020 at 9:03 AM
    Danman34
    Danman34 New Member
    Danny
    12” isn’t do or die. As long as the fuse is under the hood, you’ll never have any problems.
    Twinky likes this.
  8. Jan 26, 2020 at 9:54 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I reran mine this week, replaced 4ga cca with 0ga copper.
    I forgot about the 12" rule, maybe I should shorten my battery to fuse wire..
  9. Jan 28, 2020 at 11:44 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    The 5 Star guys build all their fuse holder brackets from scratch out of 1/8" or 1/4" ABS. Their installs are super clean.
    panicman and Twinky like this.
  10. Jan 28, 2020 at 11:48 AM
    801Tundra
    UTAH
    And your system was professionally installed? Ouch...
  11. Jan 28, 2020 at 12:20 PM
    801Tundra
    UTAH
    Not saying it's wrong... but they could have done a cleaner job for sure. If that's a 200A fuse it's probably a little big for your system, may want to swap that out for a 100amp when you get your new battery. Assuming you have the 900 watt 5 channel amp at 80% efficiency you'd be pulling around 80 amps...
    Twinky likes this.
  12. Jan 28, 2020 at 12:30 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    damn those small hoes. they're so hard to keep in line.
    Twinky and Jrharvey02[QUOTED] like this.
  13. Jan 28, 2020 at 12:32 PM
    Jrharvey02
    specially’ with a tundra, gotta beat the hoes off with a stick if I’m out after dark on Friday nights, lol.
    smslavin[QUOTED] likes this.
  14. Jan 28, 2020 at 12:54 PM
    Twinky
    07 double cab work horse
    The top of fuse lid next to the battery. Not really the best way to go about it but it is what it is.
  15. Jan 28, 2020 at 1:06 PM
    Twinky
    Good catch.
    That size fuse on a 4ga (judging by how it looks) won't actually prevent a worst case senerio. The wire will have already burned thru the jacket and most likely shorted to the chassis and there is a fire.
    100 amp is a good suggestion.
    The likely hood of that happening is extremely slim but the potential danger is up there in the scary level.
    Edit: hmm, it does look like a 0ga now that I looked at it again.
    801Tundra[QUOTED] likes this.
  16. Jan 28, 2020 at 1:13 PM
    Twinky
    Thats always a good idea. There's not really any down side to adding one there. A barrel type fuse holder would probably be a good type for that also.
  17. Jan 28, 2020 at 1:40 PM
    DSTundra
    Dave
    Albuquerque, NM
    I ended up attaching the fuse holder to the fender above the fuse box. It's about 15" from terminal to fuse holder, but I doubt that extra 3" is going to matter and it looks pretty clean. Now I just need to add some wire loom...
    Danman34 likes this.
  18. Jan 28, 2020 at 3:06 PM
    Danman34
    Danman34 New Member
    Danny
    Wire loom is my finishing touch for any wiring I do. It makes everything look oem. Lol. I even added wire loom to the wires for my a/c unit outside and my a/c guy was impressed and started putting loom on all his installs lol.
  19. Jan 29, 2020 at 6:50 AM
    Twinky
    Watts = amps x volts
    http://www.bcae1.com/
    Suggested Fuse Sizes:
    Wire Gauge Recommended
    Maximum Fuse Size
    00 awg 400 amps
    0 awg 325 amps
    1 awg 250 amps
    2 awg 200 amps
    4 awg 125 amps
    6 awg 80 amps
    8 awg 50 amps
    10 awg 30 amps
    12 awg 20 amps
    14 awg 15 amps
    16 awg 7.5 amps
    These are based on less than 20 foot runs I believe and are the largest fuse ratings that the above sites author recommends. He's the guru of this stuff so I follow his recommendations.
    His website (the link above) is an amazing wealth of knowledge.
  20. Jan 29, 2020 at 7:50 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    this is also a super handy chart to have around...
    Twinky, phogallen and NewImprovedRon like this.
  21. Feb 9, 2020 at 2:31 PM
    DSTundra
    Dave
    Albuquerque, NM
    Mine...
  22. Feb 9, 2020 at 3:52 PM
    2chains
    2chains New Member
    Southern Ablerta
    ^^I like the fact you used the loom. How is the fuse holder fastened? I was thinking of using the 3m double sided tape that is used for mounting badges.
    I got in on the last sub/amp group buy and planning my install.
  23. Feb 9, 2020 at 7:24 PM
    DSTundra
    Dave
    Albuquerque, NM
    I used the short mounting screws that came with the fuse holder.
  24. Feb 9, 2020 at 10:32 PM
    2chains
    2chains New Member
    Southern Ablerta
    I'll have a look for those I have that same kit. Which route did you take to run wire into engine bay?
  25. Feb 10, 2020 at 3:01 PM
    DSTundra
    Dave
    Albuquerque, NM
    I took out both front seats and the center console and ran the power wire across under the carpet to the driver's side then through the firewall on that side. It's more work, but it looks cleaner than having the power wire running across the back of the engine bay in my opinion. Some folks don't care about that... I also got some 14ga StreetWires Ultracable speaker wire (which is round) and drilled a hole in the divider of the subwoofer box just big enough to force that speaker wire through. That enabled me to wire the two 4 ohm, single voice coil JL Audio subs in parallel inside the box and connect them to a single terminal on the passenger side. I didn't hook up the factory subwoofer wires to the JL Audio amp, but instead ran a single length of that Streetwires Ultracable from the amp down the passenger side to the passenger side subwoofer terminal. This accomplished two things: I didn't have to run a jumper from one set of subwoofer terminals to the other externally and I didn't have to use (or more importantly cut) the factory subwoofer connector.
    Dave
  26. Feb 10, 2020 at 4:43 PM
    2chains
    2chains New Member
    Southern Ablerta
    ^^Thanks for the detailed response.
  27. Apr 16, 2020 at 12:15 PM
    4Yotasince99
    4Yotasince99 New Member
    Eric
    2018 CM Tundra TRD Sport
    Bilstein 5100 (middle setting) - front only, Driver's side grab handle installed, JL Audio upgrade from Tech 12
    I'm getting ready to install mine I got from James at Tech 12... he sent me the X2 amp install kit good for up to 1200W... comes with #4 wire and 50A fuse. Gonna be runnin the JL RD900/5. From the sounds of this thread, that fuse that comes with the kit may be undersized? They sized the fuse with the kit off the RMS wattage, which is 600 W.
  28. Apr 16, 2020 at 12:19 PM
    AZBoatHauler
    So.Arizona
    Good catch - I purchased the same amp and install kit and noticed the same. I replaced the 50A fuse with one of these 80A as 50A seems small for that much amp.
    https://www.amazon.com/gp/product/B07T8HMD71/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
  29. Apr 16, 2020 at 12:35 PM
    Vizsla
    Vizsla 2 = 2.5
  30. Apr 16, 2020 at 12:57 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
