power windows / door lock
Discussion in '1st Gen Tundras (2000-2006)' started by Barryo', Nov 2, 2020.
  1. Nov 2, 2020 at 5:23 AM
    Barryo'
    Barryo' [OP] New Member
    Hey there
    I have an 05 tundra with 445k on it. left my windows down during a rainstorm. Now my power windows and door locks do not work from the driver side control. The Windows work at each door
    and i have to manually lock the doors.
    Is there a fuse that Would control both of these items?
    thanks
    Barry
  2. Nov 2, 2020 at 5:28 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    The manual may help find that info out. Or the fuse panel cover. Never had the issue personally. Try searching on here someone may have had same issue
  3. Nov 2, 2020 at 6:27 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    My guess is the master window control switch needs to be replaced. It didn't like getting washed....
    GeezePlease and Hi06silver like this.
  4. Nov 2, 2020 at 6:24 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Yes that is my guess. Check ebay.
    On my old base model V6 tundra I added the power windows.
    If I remember right the switches do not control power. But give it ground. Same fuse should be for both windows. And would explain why the other side still works. So getting power just not ground.
  5. Nov 3, 2020 at 3:49 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I'd try removing the switch to try to dry it out. Maybe start by blowing it out with compressed air. Then bring it inside and set it on/over/in something warm. I'd set it on top of my furnace in the basement overnight. If you have radiators, maybe set it on one of those overnight. Or use a hair drier on low a few times.
