Power window won't go up
Discussion in '1st Gen Tundras (2000-2006)' started by Ty_emmons26, Mar 27, 2020.
  1. Mar 27, 2020 at 8:10 PM
    Ty_emmons26
    Ty_emmons26 [OP] New Member
    Tyler
    2006 Toyota Tundra SR5
    My passenger window won’t go up. I checked the voltage and it’s reading 12v going up and going down. Replaced the motor and regulator. No blown fuses. All other windows work. Any help would be appreciated.
    thanks.
    2006 tundra, sr5 crew cab
  2. Mar 27, 2020 at 8:54 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Switch? Try a switch from one of the other doors perhaps?
  3. Mar 27, 2020 at 9:11 PM
    Ty_emmons26
    Tyler
    From everything I’ve been reading online it’s that master switch which I’m hoping it’s not cause that’s out the ass on price. I’ll definitely try that tomorrow morning.
  4. Mar 27, 2020 at 9:16 PM
    AZTundra
    Paul
    Phoenix, AZ
    Agree, it could definitely be the switch. I'm sure you checked, but make sure the window lock button isn't pressed down as well.
    TX-TRD1stGEN likes this.
  5. Mar 27, 2020 at 9:19 PM
    Ty_emmons26
    Tyler
    Rgr, that’s the first thing I checked! I’m gonna do some more trouble shooting in the morning, it’s like the electricity isn’t making a full circuit. Maybe a short but more than likely the switch.
  6. Mar 27, 2020 at 9:20 PM
    AZTundra
    Paul
    Phoenix, AZ
    NewImprovedRon likes this.
  7. Mar 27, 2020 at 9:47 PM
    Ty_emmons26
    Tyler
    I appreciate it
  8. Mar 27, 2020 at 9:49 PM
    AZTundra
    Paul
    Phoenix, AZ
    Where did you test to get the 12v going up and down?
  9. Mar 27, 2020 at 11:14 PM
    docfnky
    docfnky New Member
    Apply power directly to the motor? If you put 12V and it goes up and down fine then it could be a relay. Look at the window when it goes up or down - if it looks like it’s binding or go too slow the window tracks on either side of the door opening could be dirty or need to be lubed.
  10. Mar 30, 2020 at 2:53 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I noticed in another thread that you asked about subwoofer and amps....by chance do you have your Center Cluster Integration Panel out working on radio ?
    The below power window troubleshooting for a 2006 from FSM may or may not help....
  11. Mar 30, 2020 at 4:05 AM
    Ty_emmons26
    Tyler
    No I hadn’t touched my radio in a few months, but I talked to my brother who is a Toyota tech and he said it’s more than likely the master switch so I bought a used one off of eBay for $60 and the guy actually threw in the passenger side switch as well so I’m hoping that it fixes the problem.
    AZTundra and bmf4069 like this.
  12. Mar 30, 2020 at 8:29 AM
    AZTundra
    Paul
    Phoenix, AZ
    I think you're on the right track. The master switch is most likely the issue. Keep us posted.
  13. Mar 30, 2020 at 9:01 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i fought a passenger window that wouldnt work... come to find out the master switch tab had broken with the window going up.. so it was always "up" so even from the passenger side it wouldnt work.. new master and it worked. (After i wasted money on a used fuse box and alot of time tracing wires)
