Power window motors
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, May 26, 2024.
  1. May 26, 2024 at 10:39 AM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Who makes a power window motor that isn't a POS other than OEM for a 2006 DC that's doesn't cos 300-500 bucks? I've not had good luck with RA because their parts catalog was incorrect.
    I thought that I had fixed my slow ass drivers window with the replacement of door track seal that was all chewed up and binding a while back but I think it was just a part of the problem. I've greased the tracks, replaced that seal and just bought a used OEM regulator with motor and it's about the same. It does lurch towards the mirror within the first inch or so of rolling down but the straightens out. Goes down decent but up drags like hell and both motors are likely weak and I have another problem or it's just the motor. Idk.
    Personal experiences.with non OEM motors and part numbers would be awesome too. Thanks.
  2. May 26, 2024 at 9:07 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I bought motor/regulator combo for under $60 including tax and shipping at CarParts .com.
    Yes, I'm sure it is cheap Chinese stuff but it's been working just fine for about a year now.
    The regulator is a different design and I was convinced they sent me the wrong part, even though the instructions warned you it was a different design than the factory regulator. But it did work just fine
    and I should add that I was replacing a cheap replacement that was always loud and noisy and dragging. The OEM one bit the dust a few years earlier. This one from car parts sounds just like the factory passenger side.
