Power Window Controls Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yotafan1969, Mar 6, 2023.
  1. Mar 6, 2023 at 10:21 AM
    Yotafan1969
    Yotafan1969 [OP] New Member
    2015 Tundra Limited
    So I had to buy a new power window master control panel for the drivers side because the plastic screw ports failed and it sent the “buttons” down into the door frame. Ordered a new master switch. Important to note for my question is that the old switches worked they were just not able to be remounted due to plastic mounts being broken. When I switched the units out the windows no longer work for either unit. The new one, or the old one.
    I checked every fuse in the box (30’s anyway) because that’s what folks told me controlled that. Could this be a relay gone bad or that I tripped and ruined? If so does anybody know which relay it is to replace / check?
    I’d appreciate any help at all. Sorry for the long post.
