Power window and door lock problem
Discussion in 'General Tundra Discussion' started by Alex261, Jan 6, 2021.
  1. Jan 6, 2021 at 6:23 AM
    Alex261
    Alex261 [OP] New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I have a 2020 platinum with driver and passenger auto up and down. The auto feature stopped working, I can’t control the passenger window at all from drivers door, the power lock button won’t work, and the little lights in the switch flicker. All I can do is go up and down with driver and back windows only. It just stopped working and nothing was done to my truck electrically. I checked all fuses and everything seems fine. Any thoughts? Thank you
  2. Jan 6, 2021 at 6:26 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Sounds like a bad connector or something. I would drop it off at the dealership since it's a 2020 and all that should be under warranty.
    Tundyfundy and Jim LE 1301 like this.
  3. Jan 6, 2021 at 6:32 AM
    X2
    Let dealership fix it, it's under warranty.
  4. Jan 29, 2021 at 4:20 PM
    Alex261
    Alex
    Boston, Ma
    Ok so two weeks ago the dealer replaced the whole panel set up and everything seemed to be working fine and today I was putting the window down and the auto down feature wasn’t working and now the two lights on drivers side and one light on passenger side (of window switches) is flickering again. Driver side now has no auto up/down feature, door lock button not working and passenger window button not working from drivers side. Same exact thing that I brought it in for the first time. I know the solution is to go back to dealer but obviously them replacing the whole switch set up is not the problem. Does anyone have any other suggestions. I’ve had nothing at all done to the truck electrically
  5. Jan 29, 2021 at 5:46 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    They may have not replaced it, they may have just lubed it up and put it back in as the TSB indicated, once it fails it has to be replaced completely... Ask me how I know... "IF" they did replace it, it should still be under a 12 month warranty, take it back...
  6. Jan 29, 2021 at 6:36 PM
    Alex261
    Alex
    Boston, Ma
    They did replace the whole unit, I could tell it was new and not scratched or anything. Is there a TSB on that? I’m wondering what the hell else it could be if it’s not the whole $400 switch assembly
