Power to the pump won't start
Discussion in '2nd Gen Tundras (2007-2013)' started by Neilpeart70, Jul 31, 2024.
  1. Jul 31, 2024 at 5:27 PM
    Neilpeart70
    Neilpeart70 [OP] New Member
    Jay
    2012 toyota tundra 5.7 4x4 base
    None
    For the last 3 weeks my truck has been down and not working I bought a new fuel pump thinking that it died because it wouldn't start it kept cranking and not starting so I dropped the tank put a new fuel pump in it tested positive and ground and it was pumping fuel put it back up in the reservoir what to start the truck and I'm getting no power back there checked relay and fuses but nothing took it to Monroe Muffler and Brake they had it for a week said it was a loose wire at the fuel pump relay got the truck last Monday he said it was low on gas I went to get the gas put it in it had two gallons in there better went to start it they left the shop and it wouldn't start I had the tow my truck all the way back home I am at wit's end I don't know what this problem is and frankly I need help
    I checked all my fuses bought brand new relays I can feel it clicking at the box but it's not transferring power to the fuel pump or the fuel pump has something going on again I doubt that though
  2. Jul 31, 2024 at 5:32 PM
    How old is the battery? Some vehicles will kill power to the fuel pump if the battery is bad.
  3. Jul 31, 2024 at 5:52 PM
    Neilpeart70
    Jay
    None
    8 yes and been hammering on it as of late
  4. Jul 31, 2024 at 5:54 PM
    Neilpeart70
    Jay
    None
    I thought it possibly could be a loose wire underneath the fuse box where the fuel pump relay was so I'm going to try to get that out to see if there's any loose or frayed wire but it's the craziest thing when I take the fuel pump out of the truck and put positive and ground to it it pumps feel like crazy
  5. Jul 31, 2024 at 5:55 PM
    Neilpeart70
    Jay
    None
    I took it to Monroe Muffler and Brake which was a mistake last Monday they worked on it for 5 hours said to come pick it up on Wednesday which was today it went to pick up the truck and it did not start and they had left the shop already guy told me to get 2 gallons of gas I would did that and then Triple A shook the fuse box while I tried to prime it and it started so I don't know it seems like there's a loose wire somewhere but I do have positive and ground at the fuel pump harness connection and all my fuse and relays are good I just put brand new ones from Napa in
  6. Jul 31, 2024 at 5:56 PM
    Neilpeart70
    Jay
    None
    If anybody out there can help me fix this problem it would be much appreciated I don't know what the hell to do anymore but my wife is on my ass like you know what, LOL
  7. Jul 31, 2024 at 5:56 PM
    Neilpeart70
    Jay
    None
    My taxes are due and I haven't worked in three and a half weeks and this is my only driver
  8. Jul 31, 2024 at 6:15 PM
    2mchfun
    Check for a bad crankshaft sensor, likely your issue
  9. Jul 31, 2024 at 6:16 PM
    2mchfun
    Fuel pump doesn't run in key on, only when cranking or running. You will not get power in key on only.
  10. Jul 31, 2024 at 6:32 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Any CELs?
  11. Jul 31, 2024 at 6:43 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Have you checked the Fuel Pump Control Module that's bolted to the frame? They have a tendency to rot out and allow water in there causing problems like you've described.
  12. Jul 31, 2024 at 7:23 PM
    AZBoatHauler
    So.Arizona
    This would be my bet.
  13. Aug 1, 2024 at 4:37 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Normally I would advise you to post in the 2nd Gen forum or Ask the Toyota Mechanic thread, but you've got some very knowledgeable people trying to help in here. I hope you get it figured out quickly!
  14. Aug 1, 2024 at 6:04 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I think his ol lady put an end to his misery.
  15. Aug 5, 2024 at 7:02 PM
    Neilpeart70
    Jay
    None
    I do have power to the power on the harness except for when I plug it in I'm not getting it to start
  16. Aug 5, 2024 at 7:03 PM
    Neilpeart70
    Jay
    None
    I'm still battling with this issue I don't know what the hell to do
  17. Aug 5, 2024 at 7:09 PM
    TILLY
    Massachusetts
    Did you check the fuel pump control module?
  18. Aug 5, 2024 at 7:13 PM
    Neilpeart70
    Jay
    None
    How do I check to make sure that my fuel pump control module is good?
  19. Aug 5, 2024 at 7:13 PM
    Neilpeart70
    Jay
    None
    Also what are the steps to bypassing the fuel pump control module if you know any?
  20. Aug 5, 2024 at 7:14 PM
    Neilpeart70
    Jay
    None
    I have a good battery brand new my relays are brand new my fuses are good I've checked all those the fuel pump does not want to Pump Fuel when I turn the key and try to start it? Perplexing
  21. Aug 5, 2024 at 7:20 PM
    TILLY
    Massachusetts
    Have you checked to see if the module is rotted out like I suggested earlier?
  22. Aug 5, 2024 at 7:21 PM
    Neilpeart70
    Jay
    None
    So the fuel pump control module while looking inside the unit doesn't have any type of corrosion at all
  23. Aug 5, 2024 at 7:22 PM
    Neilpeart70
    Jay
    None
    I'm ready to at this point put a positive and negative wire on top of the fuel pump with alligator clips and keep a battery up in my truck and disconnect it when I need it to run hahaha funny I don't know what the hell to do
  24. Aug 5, 2024 at 7:23 PM
    Neilpeart70
    Jay
    None
    I took the vehicle to Monro Muffler and Brake they said that it was fixed come pick it up which I did and it still didn't start, LOL what up got two gallons of gas put it in it tried to start it it wouldn't start they had already left the shop cuz they closed. Then Triple A came out shook the Box wiggle the relay and it started by the miracle of God I got the truck home but then the next morning I could not start it again so I put jumper cables on it charged up the battery and voila it started again. Then about 3 hours later I took the truck to go to Walmart and it died and it would not start no matter what I did
  25. Aug 5, 2024 at 7:34 PM
    TILLY
    Massachusetts
    If they shook the fuse box and it started I would definitely concentrate on that area. Maybe you have a loose wire or ground underneath that you can't see.
