Power Steering Reservoir cap leak
Discussion in '1st Gen Tundras (2000-2006)' started by garthfreeman, Aug 14, 2021.
  1. Aug 14, 2021 at 5:02 PM
    garthfreeman
    garthfreeman [OP] New Member
    Garth
    2000 Tundra access cab TRD 4x4
    Sorry if this has been asked but searching seems to bring up a lot of results for newer trucks... I am losing fluid fast from the reservoir cap, I'm pretty sure. I cleaned everything up and it is coating the reservoir all around. So the question is: am I looking at a new cap, or is there a larger problem? The truck is a 2000 Tundra, 4.7 4x4 extended cab (Access cab?) TRD. It just doesn't seem like there should be that much pressure coming back into the res... And nobody sells a cap, so... The gear was whining when the fluid went low, but it quieted right down with new fluid, until it leaked again.
    No real steering issues that I can tell. I haven't had the truck long, and it's high mileage, but it turns easily, responds quickly, and doesn't seem to have much, if any, slop. Just looking for some ideas because the parts aren't cheap, res is a hundred bucks, pump more, rack even more... Thanks in advance.
  2. Aug 14, 2021 at 5:17 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    It actually could be a result of air in system if it's done it enough even before you bought !
  3. Aug 14, 2021 at 7:50 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Best way to try and bleed power steering is to put it on Jack stands or soft surface (to prevent tire wear) and open the res cap and turn wheels back and forth for a little while.
    garthfreeman[OP] likes this.
  4. Aug 18, 2021 at 6:34 AM
    garthfreeman
    Garth
    It seems like air in the system was the problem. I flushed it, put a couple new hoses on, and it works like a champ now. Thanks!
    Bad Jackson and BubbaW like this.
