Power Steering Pump
Discussion in '1st Gen Tundras (2000-2006)' started by tigerflyer, Dec 28, 2022.
  1. Dec 28, 2022 at 5:37 PM
    tigerflyer
    tigerflyer [OP] New Member
    Bill
    Great White North (Ontario Canada)
    06 AC, 14 DC, 06 DC
    Level kit on the 06, 14 is bone stock
    Hi. New member here, but not new to Tundras. I recently had a return line break in the power steering system, and wound up with a dry running pump for about a minute of two. After I repaired the line, and filled it with new fluid, it was working fine, until I got the truck stuck, and was revving it trying to out of the snowbank. Now the fluid has turned totally black, and I have no power steering (or any steering) at idle.
    By running the pump dry for 1 or 2 minutes did I fry it??
  2. Dec 28, 2022 at 5:59 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Kind of sounds like it. Maybe you can confirm by placing your finger in the reservoir and feeling for suction with the hose to the pump while the truck is running?
    I’m sure one of the other members here will chime in with a better idea.
  3. Dec 28, 2022 at 6:21 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    I am not questioning you, I know you wrench a lot. Just asking for my own knowledge. Will you feel that sxn at idle without the steering pump engaged?
    I’ve had high pressure lines weeping for almost a year
  4. Dec 28, 2022 at 6:36 PM
    Jack McCarthy
    Bill
    North of Boston
    I’d have to double check myself. I did notice that fluid was flowing in the reservoir while the truck was sitting at idle so I assumed you’d feel some suction coming from the intake to the pump line. I’d check it now, but it’s late here. I may try it tomorrow morning when I have some time.
  5. Dec 28, 2022 at 6:39 PM
    MEWaters
    MEWaters New Member
    Maine
    Yea late and cold here, too. Don’t check and report for my sake. If it’s not in you memory bank don’t sweat it
  6. Dec 28, 2022 at 7:00 PM
    tigerflyer
    Bill
    06 AC, 14 DC, 06 DC
    Just to let you know, once I get the revs up the steering works. But trying to turn city street corners is an iffy thing. :)
    Jack McCarthy likes this.
  7. Dec 29, 2022 at 12:26 PM
    Jack McCarthy
    Bill
    North of Boston
    Well forget my idea. I took a closer look at the reservoir. You can’t really get your finger in there anyway to check.
