Power steering pump whine
Discussion in '1st Gen Tundras (2000-2006)' started by randyt3, Mar 23, 2021.
  1. Mar 23, 2021 at 8:51 AM
    randyt3
    randyt3 [OP] New Member
    2003 Toyota Tundra Sr5 T3 edition
    Hey guys, another question ‍‍♂️ Did my power steering pump replacement on Sunday and it’s making this whine, it goes away after a while idling but it’ll come back when accelerating and especially turning it gets loud enough to be embarrassing.. could it be the pump? It was a remanufactured cardone pump, the steering feels better even with the pump it’s just the noise I cannot handle. I tried the method Toyota says by jacking up the truck and turning the wheels click to click, but what else should I look for? I just don’t want to damagethe pump if it’s another issue that’s causing this.
  2. Mar 23, 2021 at 8:52 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Have you bled the system since installation?
    Using the correct trans fluid in the steering system?
    FrenchToasty likes this.
  3. Mar 23, 2021 at 9:04 AM
    randyt3
    I used prestone power steering fluid, maybe that’s where I went wrong? But i did bleed it the way Toyota says, maybe I’ll try again just in case i did it wrong, but it says jack up the front, turn the wheels each side a couple of times but I do not open up the reservoir when doing this correct?
  4. Mar 23, 2021 at 9:14 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Should be Dex II or III ATF.
    I highly recommend a flush if the Prestone stuff you used isn't Dex II or III spec.
    [​IMG]2021-03-23_10-12-02 by GhostCreekMine, on Flickr
    RustyShackle323 likes this.
  5. Mar 23, 2021 at 9:15 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Indeed. If you look on the cap, it tells you to use ATF like Glock40 mentioned.
  6. Mar 23, 2021 at 9:17 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  7. Mar 23, 2021 at 9:19 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Jack McCarthy likes this.
  8. Mar 23, 2021 at 9:22 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  9. Mar 23, 2021 at 9:26 AM
    randyt3
    Well I had a family mechanic of mine replace the pump, he didn’t really flush any of the fluids he just topped it off with the prestone and attempted to bleed the air out on the ground. Is flushing the system a hard process? I’d like to do it myself to make sure everything is properly done
    Glock 40 likes this.
  10. Mar 23, 2021 at 9:27 AM
    randyt3
  11. Mar 23, 2021 at 9:28 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  12. Mar 23, 2021 at 9:30 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Fluid is contaminated by Prestone stuff... flush. Your guy has created a new chemical cocktail. Pump might not likey the new drink.
    Also, follow the bleeding procedure to a tee. Have someone steering and someone monitoring the reservoir. 2 person job, no lifting advised.
  13. Mar 23, 2021 at 9:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Hang around them a little longer, they love helping you with your bank account !
    :spending:
  14. Mar 23, 2021 at 9:35 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    HELLS YA! I highly recommend lifting that beautiful T3. Supercharger and headers are also a great idea.
    BubbaW[QUOTED] likes this.
  15. Mar 23, 2021 at 9:40 AM
    randyt3
    Haha thank you, thought about it down the line, but right now I’m taking it step by step with the engine . And you mean no lifting advised as lifting the truck??
  16. Mar 23, 2021 at 9:48 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Just sayin you don't need to lift it when doing the bleed or flush. Park it flat.
  17. Mar 23, 2021 at 9:49 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Just joking about recommending an offroad lift, kinda.
  18. Mar 23, 2021 at 10:11 AM
    baltimorebirds2
    baltimorebirds2 New Member
    2004 Tundra Access Cab LTD 4x4 Salsa Red (TOTALED)
    Isn’t the clear/yellow stuff they use from the factory PS fluid?
  19. Mar 23, 2021 at 10:36 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    My understanding is that it's not. Supposedly they have access to clear Dexron 2 or 3 fluid. The red color is just a dye sold to the public from what I understand to make it easily distinguishable.
  20. Mar 23, 2021 at 4:18 PM
    Professional Hand Model
    Hand Protectors
    DEX/Merc is the fluid you want.
    Toyota Steering Pump is the part you want.
  21. Mar 23, 2021 at 4:29 PM
    Rocko9999
    Rocko9999 New Member
    Could be the replacement is bad also, but always put all new fluid in when replacing, takes the guess work out of whether it's the fluid or not.
    randyt3[OP] and Glock 40 like this.
  22. Mar 27, 2021 at 9:46 AM
    randyt3
    Update : flushed the entire system with valvoline multi atf, pump is 10 times quieter, still makes a tiny whine, but overall it’s very much so better than before with the fake supercharger whine it gave. Thank you all ! I’ll be doing a double din radio install and some different speakers this weekend hopefully, if I get around to it !
