Power steering pump replacement?
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenTundra, Feb 18, 2016.
  1. Feb 18, 2016 at 5:12 PM
    FirstGenTundra
    FirstGenTundra [OP] R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Anyone have any knowledge or experience with replacing a first gen power steering fluid pump? I believe mine is going bad after 175000 miles. The fluid is dirty, looks almost like clean motor oil. And when I first start the truck and start rolling the steering wheel has more resistance than usual. The pump is also starting to make more noise than it use to. It sounds almost like a worn out water pump. Kind of has a howl to it. Any info would be appreciated. I believe its a task I can take on but don't know if there are any special tools that I need.
  2. Feb 18, 2016 at 5:23 PM
  3. Feb 18, 2016 at 5:25 PM
    FirstGenTundra
    Daniel
    Wyoming
    I just saw that thread and asked over there, sorry for the mix up.
    T-Rex266 likes this.
  4. Feb 18, 2016 at 5:50 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    ... would you like PDF's from the Chilton repair manual?
  5. Feb 18, 2016 at 5:58 PM
    FirstGenTundra
    Daniel
    Wyoming
    I do have the Chilton's PDF download but thank you very much!
  6. Feb 18, 2016 at 6:00 PM
    Nor7
    See attached, let me know if you need anything else. There are two sets of instructions to bleed the system, do you have Rear Wheel Anti-Lock (RWAL) brakes?
  7. Feb 18, 2016 at 6:00 PM
    Nor7
    Ah, ok just saw this after I uploaded them.
  8. Feb 18, 2016 at 6:02 PM
    FirstGenTundra
    Daniel
    Wyoming
    Perfect, thanks brother! I will check them out, its a pain trying to find things in the PDF. lol
  9. Feb 18, 2016 at 6:03 PM
    FirstGenTundra
    Daniel
    Wyoming
    And no, no anti-lock breaks.
  10. Feb 18, 2016 at 6:03 PM
    Nor7
    Yeah, one of them is the actual instructions and the other three are enlarged images from the instructions.
  11. Feb 18, 2016 at 6:04 PM
    FirstGenTundra
    Daniel
    Wyoming
    You are the man, thanks again for your time.
  12. Feb 18, 2016 at 6:05 PM
    Nor7
    Ok, well here it is if you need it.
