Power steering pump noise
Discussion in '1st Gen Tundras (2000-2006)' started by steeleb, Aug 7, 2021.
  1. Aug 7, 2021 at 9:32 AM
    steeleb
    steeleb [OP] New Member
    Hi everyone! Need help with power steering pump making a knocking noise. I replaced with a new pump and the new pump is making the same knocking noise, and the fluid in the reservoir is extremely hot and overflows
  2. Aug 11, 2021 at 11:36 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    How does the belt look? And the fluid?
    What makes you think it's the pump and not the rack?
  3. Aug 11, 2021 at 6:07 PM
    steeleb
    I am starting to think it is the rack especially after replacing the pump. I haven't had much experience with a rack and pinion. I think that is the next step.
    Thanks for your comment
    Glock 40 likes this.
  4. Aug 11, 2021 at 6:17 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Judging by your explanation it does sound like your rack may be the culprit. Is there any fluid seepage coming from the rack? What color is your PS fluid... and does it smell burnt?
    And welcome to the forum!
  5. Aug 12, 2021 at 6:08 AM
    steeleb
    The rack is not leaking, the fluid doesn't smell burnt and the fluid has been changed. I don't understand why the fluid gets so hot. I know it will get hot under pressure but it seems like it is too hot. maybe normal IDK. We are going to replace the rack and hopefully that will fix. I will keep you posted and thanks for your input.
  6. Aug 12, 2021 at 6:31 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Are you using ATF for fluid?
    bmf4069 and Jack McCarthy like this.
  7. Aug 12, 2021 at 6:34 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Does the power steering itself work fine?
