Power steering pump noise with A/C
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thomaskwood, Mar 24, 2025.
  1. Mar 24, 2025 at 1:26 PM
    Thomaskwood
    Thomaskwood [OP] New Member
    Thomas
    2014 Tundra 5.7
    2014 SR5, Power steering pump sounds like it is sucking in air. Only hear The obvious power steering pump noise with AC turned on.
    First, I replaced the pump with no improvement. Noticed a very slight power steering fluid leak so I replaced the pressure line going to the rack/pinion. Still no change
    Water pump gas gasket was lightly leaking so I changed it and a brand new belt. Now everything seems to be perfect with the engine, except for the classic power steering pump cavitation sound only when air conditioner is turned on… any ideas?
