Power Steering HELP
Discussion in 'General Tundra Discussion' started by dae1041, May 15, 2018.
  1. May 15, 2018 at 11:20 PM
    dae1041
    dae1041 [OP] New Member
    I have been having problems with my power steering. It started off gradually getting stiff over the course of a couple weeks. After about two weeks my front brake pads went out (not sure if related or just a coincidence) After replacing my brake pads, I went to the dealership for a Diagnostic. They suggested I replace the Power steering pump, pressure sensor and gave me a $1600 quote. I replaced the pump and the sensor my self and still no luck. HOWEVER after getting the power steering flushed, my steering was smooth. BUT only for a few hours and then it started stiffening up. Any suggestions????
  2. May 15, 2018 at 11:47 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Hmmmm, sounds like your losing fluid somewhere, have you checked inside the power steering rack boots?
  3. May 15, 2018 at 11:49 PM
    dae1041
    Levels seem fine but no I haven't checked. I haven't seen any leaks dripping on to the ground.
    Thegr8punkin likes this.
  4. May 15, 2018 at 11:56 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  5. May 15, 2018 at 11:59 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Is it possible you replaced is with another bad pump? I wouldn’t think so but just curious
  6. May 16, 2018 at 12:00 AM
    dae1041
    It could be possible.. I bought it third party from advance auto parts. Wish
    I could know for sure
  7. May 16, 2018 at 7:18 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    It's possible you got a defective part but I would try and bleed the system and also check the tie rod ends for grins.
  8. May 16, 2018 at 8:07 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    On one of my older cars that I sold I had to have the fuel pump replaced 3 times before one worked right. It was frustrating for sure.
  9. May 16, 2018 at 10:49 AM
    UncleJimmy
    UncleJimmy New Member
    I just replaced the steering pump, rack and lines. You may need to look at the rack.
  10. May 16, 2018 at 5:21 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    On your steering shaft, just above the steering rack, you will find a universal joint. Soak it with penetrant like PB Blaster, Moov-it, and see if your symtoms disappear. If they do, replace the lower shaft assembly.
