Power Steering Fluid Exchange?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Jan 23, 2021.
  1. Jan 23, 2021 at 5:41 PM
    Rocko9999
    Rocko9999 [OP] New Member
    At 156K my 14' power steering fluid looks done. I was planing on doing multiple exchanges via turkey baster except the reservoir opening is too narrow for the baster to reach the fluid. Any ideas on an easy/best way to exchange the fluid?
  2. Jan 23, 2021 at 5:46 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Mityvac
  3. Jan 23, 2021 at 5:53 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    2mchfun likes this.
  4. Jan 23, 2021 at 5:55 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I have a pneumatic brake bleeder that I shove into the reservoir.
    I have also used an old syringe from the medicine cabinet and put a small diameter hose on it in the past.
    Can also try to fit a small water bottle under the return nipple. Unhook the line and let the reservoir empty out.
  5. Jan 23, 2021 at 6:50 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    IV tubing, or similar, attached to a 60cc syringe, or turkey baster. Why don’t you use the needle that comes on the turkey baster?
    Rocko9999[OP] likes this.
  6. Jan 23, 2021 at 6:55 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  7. Jan 24, 2021 at 7:08 AM
    Rocko9999
    I got my baster at the dollar store. No needle or syringe. I will look for some small tubing to attach to it. Thanks.
  8. Jan 24, 2021 at 9:28 AM
    SShooterZ
    SShooterZ New Member
    Pull it out with a hand pump that dumps into a measuring cup. Dump out the old, fill up new to where the old stuff was and refill. Should get you right back to the full line.
  9. Jan 24, 2021 at 9:47 AM
    The Patriot 1776
    '16 TSS CM 4x4
    I suck out about 3/4 of what’s the the reservoir. Not all of it or you will introduce air into the system. Then I fill to the full mark, drive a few days and repeat. I do this until the fluid looks new again. I do this for power steering and brake fluid. It’s always worked well for me and takes very little time/effort.
    YardBird likes this.
  10. Jan 25, 2021 at 11:03 AM
    Rocko9999
    Found some tubing and got it attached to the baster. Need to do many more exchanges to get this clean.
    YardBird and MatD13 like this.
  11. Feb 8, 2021 at 11:18 AM
    Rocko9999
    Since draining and refilling the reservoir 5X, I think I am hearing a bit of pump whine when cold. Goes away when the truck is warm. I used MaxLife ATF. Could the reservoir screen be clogged or is this a fluid type issue?
  12. Feb 8, 2021 at 6:00 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I use MaxLife & have had no issues. How cold? How long have you had this truck?
  13. Feb 8, 2021 at 7:20 PM
    Rubberdown
    Power steering pumps are self bleeding. Doesn’t matter if you have air in the system or not. Crank the wheel back and forth and all the air will come out. So empty the reservoir and swap it out!
  14. Feb 9, 2021 at 12:32 PM
    Rocko9999
    40F or so. The resevoir was really dirty before I exchanged fluid. I was thinking screen is clogged, I didn't bleed it enough or fluid incompatibility? Was thinking of pulling reservoir and cleaning it well with brake cleaner.
  15. Feb 9, 2021 at 1:40 PM
    realprotundra
    realprotundra Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock TRD Pro DC
    You are doing nothing at all for your brake fluid by doing that. The brake system is returnless. The reservoir is just there to ensure there is fluid for the system and no air can get in. The only way to flush a brake system is to run new fluid all the way through the system which pushes all of the old fluid out. Typically done by bleeding from the bleeders on the calipers/wheel cylinder.
    crewmaxlmt likes this.
  16. Feb 9, 2021 at 3:26 PM
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    Use the top off of a spray bottle. Takes longer but available and cheap.
  17. Feb 9, 2021 at 3:48 PM
    Rocko9999
    And just spray old fluid in to a container?
  18. Feb 9, 2021 at 4:39 PM
    Ericsopa
    Ericsopa Old man and the sea
