Power seat options for 2006 Tundra DC 2WD
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Oct 27, 2023.
  1. Oct 27, 2023 at 6:52 AM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    In desperate need of upholstery work on, at a minimum, my driver's side manual bucket seat.
    I've already added a new stereo with mobile car play and a backup cam and there aren't too many newer model options that I feel like I need or desire at this time, but power seats is something that I am considering, mostly because the driver's seat already needs significant work so now would be the time.
    It would be nice to upgrade the passenger side to power, but since I'm a selfish bastidge and 80% of the time or better I have no passenger it isn't a big deal if the passenger side is manual.
    My question is which other seats are compatible? I believe I read where 05-07 Sequoia seats are plug and play (except for power).
  2. Oct 27, 2023 at 7:11 AM
    No advice, just a point: My '06 Limited has OEM power seats. Passenger is manual. I think this was the case for all AC out of the factory, at least. I'm not sure if DC and Sequoia are different in that regard.
    Weagle[OP] likes this.
