Power problem?
Discussion in 'General Tundra Discussion' started by Lskeezy, Mar 12, 2017.
  1. Mar 12, 2017 at 4:36 PM
    Lskeezy
    Lskeezy [OP] New Member
    Logan
    2008 Navy Tundra SR5
    took my tundra out to go to town when I got on the highway to speed up I noticed I had no power when I hit the gas and the RPMs stayed normal for what they would have been at 35 mph. I had the petal to the floor and the highest the RPMs went we're 3.5??? Any advice on what could be causing this??
  2. Mar 12, 2017 at 4:37 PM
    TheBeast The Beach
    MAF maybe ?
  3. Mar 12, 2017 at 4:43 PM
    Lskeezy
    Logan
    It does have a check Engine light that came on problem is I don't want to chance driving to town.
  4. Mar 12, 2017 at 4:45 PM
    TheBeast The Beach
    do you have the diagnostic tool to pull the codes ?
  5. Mar 12, 2017 at 4:48 PM
    Lskeezy
    Logan
    I think I could get my hands on one to borrow if not I will go buy one would a MAF throw a code?
  6. Mar 12, 2017 at 4:52 PM
    TheBeast The Beach
    in the mean time you could try cleaning your MAF with MAF cleaner. See if that helps.
  7. Mar 12, 2017 at 4:54 PM
    TheBeast The Beach
  8. Mar 12, 2017 at 4:55 PM
    TheBeast The Beach
    did you change spark plugs, coils on your truck ?
  9. Mar 12, 2017 at 4:55 PM
    TheBeast The Beach
  10. Mar 12, 2017 at 5:01 PM
    Lskeezy
    Logan
    No I have not changed plugs or coils recently replaced serpentine belt about a month ago that is the only thing I have done under the hood other than change oil
  11. Mar 12, 2017 at 5:37 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You'll need the code(s), otherwise anything that we post is for nothing other than because we like to read our own posts.
    Lskeezy[OP] likes this.
  12. Mar 12, 2017 at 5:56 PM
    Lskeezy
    Logan
    P0418
    P2445
    P2245 pd
  13. Mar 12, 2017 at 6:08 PM
    TheBeast The Beach
    looks to be the secondary AIP issue. It might still be under warranty.
  14. Mar 12, 2017 at 6:18 PM
    Lskeezy
    Logan
    So would it be best to call the local dealer and give them the codes and see if it under warranty? Only has 130,000 of that would make a difference?
