Power outlet problems
Discussion in 'General Tundra Discussion' started by Bigchat1, May 6, 2017.
  1. May 6, 2017 at 2:43 PM
    Bigchat1
    Bigchat1 [OP] New Member
    Paul
    2006 Toyota Tundra
    Hello guys, newbie here! I was wondering if anyone has had issues with the extra power outlets in your 2006 Toyota Tundra SR5? If so please share any tips you may have. On my Tundra the main cigarette adapter works however the truck comes with two additional plugs on the side labeled 12V 120w and one in the back under the right cup holder area. I have checked them several times but cannot seem to get power to them. I have checked fuses under the hood and checked the 15A fuse talked about in one post of the forum and the fuse checks good. Can you guys point me in the right direction? Thanks so much!
  2. May 6, 2017 at 7:05 PM
    Where do you have power at currently? At fuse? Is your problem between the fuse and outlet?
    NewImprovedRon and Bigchat1[OP] like this.
  3. May 6, 2017 at 8:25 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The 15A fuse you checked, was that the one in the dash, looking at the fuse panel, far right, second one from the bottom? I was trying to upload a picture (have my friends '06 here right now) but photobucket was down.
    The body control module is also involved, since those outlets stay hot for 2 hours after key-off. I can't seem to dig up a diagram though.
  4. May 7, 2017 at 8:27 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Are you checking them with the key in the accessory position? Mine (2011) do not work unless the key is turned on.
    Bigchat1[OP] and NewImprovedRon like this.
  5. May 8, 2017 at 8:19 AM
    Bigchat1
    Paul
    2006 Toyota Tundra
    Thanks for your replies... Landphil, yes it the fuse you described that I checked to be good. Where is the body control module located?
  6. May 8, 2017 at 8:24 AM
    Bigchat1
    Paul
    2006 Toyota Tundra
    Hello ColoradoTJ, Thanks for your reply. I currently have power at the fuse and the main power outlet next to the ashtray works fine, I just have not been able to get the other three power outlets to work. any special areas I should check?
  7. May 8, 2017 at 8:28 AM
    Bigchat1
    Paul
    2006 Toyota Tundra
    Hello Alalmcgrath, thanks for your reply. Yes I checked them all with the vehicle running and could not get power. My main power outlet located next to the ashtray works with no problems, but I cannot get the other three to work. Any ideas of areas I should check?
  8. Jul 4, 2018 at 7:16 AM
    Graybushactual
    Graybushactual New Member
    Derrick
    Did you ever get the problem fixed? I am having the same issue with the Tundra I recently purchased
  9. Oct 23, 2019 at 7:03 PM
    Chadwick_28
    Chadwick_28 New Member
    Chad
    I am having the same issue. Did you ever get any resolution?
