power outlet cover ? Rear. Console. Crew max
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Oct 28, 2016.
  1. Oct 28, 2016 at 2:20 PM
    TheBeast [OP] The Beach
    looking for a cover for my rear power outlet. The one facing the rear seat between the 2 air vents. Not sure on the size or part#
    @Roman
    2012 Crewmax.
  2. Oct 28, 2016 at 3:59 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
  3. Oct 28, 2016 at 4:02 PM
    thanks. there is #21 which is for the rear but double cab. Crewmax maybe #18 but it might be for the front.
    #30 doesn't look like mine.
  4. Oct 28, 2016 at 4:10 PM
    joeguam
    joeguam New Member
    JOE
    If you click #21 the first choice is for the rear. Sometimes description (regular and double cab) is not always as intended. But Roman would have a definite answer plus I can not refund you if I am wrong. ;)
    TheBeast[OP] likes this.
  5. Oct 29, 2016 at 10:18 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  6. Nov 5, 2016 at 1:37 PM
    that was the correct part. Swapped them out this morning. Now my OCD wont kick in each time I don't see a cover there. thanks
    Roman and NewImprovedRon like this.
  7. May 26, 2021 at 10:43 AM
    codyneedles
    codyneedles New Member
    Roseburg, OR
    2015 SR5 Crewmax
    remote start, diamondback cover, oem led headlights, led fog lights
    2015 SR5 crewmax. I am trying to find the part code for the rear facing power outlet cover that faces the backseat but am having a hard time finding the correct one. anyone have the part #? any help would be appreciated.
  8. May 27, 2021 at 4:49 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    FWIW - The cover for my rear facing lighter wouldn't stay on (pivot) when opening...I purchased a flush mount USB adaptor, plugged it in, filled the hole, and forgot about it. Note; the rear seat lighter on my Tundra stays on for an hour or so after the truck is turned off. (the USB adaptor has an LED that lights up when on)
