Power loss offroad
Discussion in 'General Tundra Discussion' started by Spvrtan, May 6, 2018.
  1. May 6, 2018 at 9:48 PM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Background: I'm on 40" tires, supercharged, regeared to 4.88s, and have a rear air locker on my Tundra.
    This happens maybe 5% of the time I'm on a technical rock crawling trail but the truck completely gives up as far as momentum goes. The engine runs but I can floor the pedal and get no RPMs going. It typically happens when I've stopped on some rocks and there's a giant boulder or two behind (or in front) of one or two of the wheels and I'm going uphill (either forward or in reverse). I'm talking boulders that are over half the height of my 40" tires. Even with the rear air locker the truck wouldn't budge.
    We disconnected the battery for a few minutes last night on our trail run and I think it fixed it but I'm not sure since there wasn't too many hard obstacles left to get hung up on; doing this resets the computer's learning of your driving habits and other knowledge.
    Vmost66 and Jsena like this.
  2. May 6, 2018 at 9:52 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :popcorn:
    jewsNbrews likes this.
  3. May 6, 2018 at 9:53 PM
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    So when you hit the gas, the engine does or doesn't rev toward redline?
  4. May 6, 2018 at 9:54 PM
    Spvrtan
    Kris
    San Diego, CA
    Doesn't rev at all.
  5. May 6, 2018 at 9:54 PM
    Lars
    Lars
    Cedar Creek Texas
    That squashes my torque converter failing theory.
    Sunnier and Albertaundra like this.
  6. May 6, 2018 at 9:56 PM
    Lars
    Lars
    Cedar Creek Texas
    and in 4Lo all the Nannies are turned off iirc.
  7. May 6, 2018 at 9:58 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Traction control or stability control. I found you have to hold the traction button down to disengage it. Even with 4lo.
    Sunnier likes this.
  8. May 6, 2018 at 10:02 PM
    Spvrtan
    Kris
    San Diego, CA
    Fuck. I really hope that's not it. I do forget sometimes to completely turn it off after going into 4-low, haha.
  9. May 6, 2018 at 10:03 PM
    Spvrtan
    Kris
    San Diego, CA
    To clarify, I normally do the "1 press, 3 second hold, 3 second hold" while in 2-high off the bat when offroading but sometimes when I go straight to 4-low I forget to do the extra 3 second press if I didn't do it initially.
  10. May 6, 2018 at 10:04 PM
    Albertaundra
    David
    It may habe something to do with that. I remember once in mud I could hear the brakes doing there thing and I believe it cuts power to the engine at the same time.
  11. May 6, 2018 at 10:06 PM
    Spvrtan
    Kris
    San Diego, CA
    https://www.youtube.com/watch?v=MsW44QboqCg
    Also.. here's exactly where it died last night. This is a video from the perspective of the YJ that was following me (ie. you'll see my truck in front of him) and the first part of the video shows where I got stuck; I ended up winching out a bit since I had no revs backward or foward. It's a completely off-camber spot while going uphill and barely wide enough for Jeeps so I was riding the rocks and at one point when my revs vanished my passenger side was half an inch from the rock face on the right -- I did tape my passenger rear door a bit down to the metal (ie. not a dent but the paint got eff'd).
    Edit: His video doesn't really show the fact that as I got out of that first part I actually made the obstacle easier by breaking down some of the rocks.
    Jsena likes this.
  12. May 6, 2018 at 10:08 PM
    Albertaundra
    David
    Let us now if thats the case. My Taco doesnt have the nannies so I originally thought the Tundras 4lo would cancel them out...nope. kinda frustrating.
    My tundra will never see trails like what youre driving but its good to know.
  13. May 6, 2018 at 10:19 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Man!!! You guys go up rocks n shit like that in the tundras .. lol.. way to tight of a squeeze between those rocks for me
  14. May 6, 2018 at 10:22 PM
    Albertaundra
    David
    I almost cried when my truck got keyed for fsakes. Lmao
  15. May 6, 2018 at 10:28 PM
    Spvrtan
    Kris
    San Diego, CA
    Haha.. this might trigger you guys then.. this was from the trail run.. I have 3 or 4 other spots with clusters of scratches like this all over the truck but this is the first one down to the metal..
  16. May 6, 2018 at 10:29 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :oops::eek:
  17. May 6, 2018 at 10:34 PM
    Nick T
    Nick T New Member
    Nick
    Smart brake acting up? Are you holding the throttle less then 25% and letting the brake up ?
  18. May 6, 2018 at 10:36 PM
    Spvrtan
    Kris
    San Diego, CA
    Don't think it was the brakes because that wouldn't explain the 0rpm -- or I could be wrong.
  19. May 6, 2018 at 10:38 PM
    Albertaundra
    David
    Lol whatd you wash it with? a rake?
  20. May 6, 2018 at 10:46 PM
    Spvrtan
    Kris
    San Diego, CA
    Don't we all use sandpaper to clean the grime off our rigs? I hope I'm not the only one.. :p
    PomDad and Sunnier like this.
  21. May 6, 2018 at 10:57 PM
    Nick T
    Nick T New Member
    Nick
    If you are on the gas first and then tap the brakes (while still on the gas) this will activate Smart Stop... engine will lose power and go to idle. But if it's going to 0 rpm like you said, i have no idea.
  22. May 6, 2018 at 11:02 PM
    Spvrtan
    Kris
    San Diego, CA
    Yea, it's not that. I mean I'd be at full stop to hold the truck from rolling back but then I let off completely and step on the gas (ie. all the way to the floor) and get 0rpm; I wasn't two-stepping the pedals like some obstacles require.
  23. May 7, 2018 at 5:12 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    I used to race my 2011 supercharged Tundra. I can tell you that anytime I put the truck in 4 low with both nannies off the minute I floored it the computer simply cut the power. I tried multiple times to fix it and finally decided to run it in 4 high with the nannies off. I came to the conclusion the transmission couldn’t shift fast enough to keep up with the engine when it was in 4 low. Thankfully it happened during time trials instead of actual races.
    Sunnier likes this.
  24. May 7, 2018 at 6:10 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I put mine in 4hi on a gravel road just to see if it worked, does this allow me into the 4x4 club? Seriously though, I brushed some azaleas in the yard with my MGM and about shit my pants when I saw the dust stuck to the lines of dew down the side. :eek: thought it was scared for life.
    Sunnier likes this.
  25. May 14, 2018 at 7:57 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    i'd be willing to bet it was traction control, i've forgotten to turn it off a few times off road and always smack myself in the head when i figure out that was it.
  26. May 14, 2018 at 8:43 AM
    Albertaundra
    David
    @Spvrtan were you able to track down the bugs?
  27. May 14, 2018 at 11:15 AM
    thetroll262
    thetroll262 New Member
    2010 Black Tundra Limited TRD
    I have experienced the same phenomenon. Both times I was backing up a steepish hill. Once was in mud, once on dry dirt. First time I was in 4wd with all the nannies off. Second time 2wd all traction aids engaged. Both times I was backing up, lost momentum and stopped. Once stopped, I could not get the engine to rev and break traction. It was like the tuck sat down in the middle of the trail and refused to go any further.
    I think the only solution is to convert to 6 speed manual and or, carry more speed....
    Sunnier likes this.
  28. May 14, 2018 at 11:16 AM
    thetroll262
    For reference, truck is N/A, 33s, stock gearing.
  29. May 14, 2018 at 11:35 AM
    n2deep
    n2deep Pavement Princess
    Whenever i am in 4lo i always go to manual shifting and never had my truck do that.
    @Spvrtan what trail is that? I wanna run it.
  30. May 14, 2018 at 12:27 PM
    Albertaundra
    David
