Power inverter project...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dragracer_Art, Sep 2, 2020.
  1. Sep 2, 2020 at 8:22 AM
    Dragracer_Art
    Dragracer_Art [OP] New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Having been spoiled by the onboard inverter in my 2018 Tacoma... I decided I would throw one in my Tundra.
    Parts ordered sofar:
    Dash switch:
    https://www.amazon.com/gp/product/B019FUGZJU/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    80a Relay:
    https://www.amazon.com/gp/product/B01KFKEFZA/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
    500w Sine Wave inverter:
    https://www.amazon.com/gp/product/B082MDRC64/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    Panel outlets:
    https://www.amazon.com/gp/product/B07SDG8GH5/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    The gameplan here is to mount the inverter somewhere under the hood and put two outlets in the console. One in the passenger side so my wife can plug her laptop in and one in the rear for the kids if needed. I have no need for anything in the bed area... so that's off my radar.
    The dash switch should look and function like OEM to turn the inverter on/off via the 80a relay.
    I will update with pics and progress when I dig into it.
    wrechst, sf319, jtwags and 7 others like this.
  2. Sep 2, 2020 at 8:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    cool project!
    I wonder if you would be better off having the relay triggered by the ignition, that way when the trucks off the inverter is off.
    edit: looks like in the comments someone said it pulls 1.2w at idle. Barely anything, but something to think about.
  3. Sep 2, 2020 at 8:53 AM
    timsp8
    NY
    Following. I’ve been thinking about doing something like this.
    Would it get too hot under the hood?
  4. Sep 2, 2020 at 9:02 AM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    The dash switch will (by default) only function when the truck is running... (since im wiring it as such) so it will 'kinda already work that way. :thumbsup:
    The inverter will be powered off at all times unless its needed... and then will only work if truck is running and switch is on.
    PeakIT likes this.
  5. Sep 2, 2020 at 9:03 AM
    Danimal86
    Daniel
    Sacramento, CA
    Gotcha. Good thinking!
  6. Sep 2, 2020 at 9:06 AM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I will look at alternative locations if needed... but doubt it will be a problem.
    Havent been able to find recommended operating temps anywhere in the ad. May need to read the literature that comes with it.
    I can always mount it behind the rear seat.
    timsp8[QUOTED] likes this.
  7. Sep 2, 2020 at 9:15 AM
    timsp8
    NY
    I was thinking of putting one behind or under the backseat in the esp storage with lid removed. I got an oem tundra outlet to use. I was going to mount it in the rear of the console, but like the one you linked. One issue with the inverter in the truck is running big enough cables for that distance.
  8. Sep 2, 2020 at 9:46 AM
    Rolling Biome
    Rolling Biome New Member
    Denver, CO
    2019 Tundra CM Limited TRD Off Road
    I mounted mine behind the rear seat. Ran about 18 feet of 1/0 power wire from the battery. I wanted to mount it in my ESP storage tray but couldn't fit it. I ended up putting a distribution block in the ESP tray for the inverter and a future fridge.
  9. Sep 2, 2020 at 9:54 AM
    oldscout1001
    oldscout1001 New Member
    2008 Radiant Red Toyota Double Cab SR5 TRD Off Road
    I got my wife a power inverter she just plugs into the power outlet in her car. She loves it. She's a home health nurse and doesn't understand why none of her co works have one. They are a must have for any road warrior.
    NewImprovedRon likes this.
  10. Sep 2, 2020 at 9:58 AM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Yeah my wifes job has been working from home for about 6mos now... so if we go anywhere on my day off during the week... she needs the laptop to come along and we are at the mercy of the laptop battery at that point.
    My Tacoma had a 100/400w factory inverter and it was able to keep her laptop alive during roadtrips... so I figured a stand-alone 500w unit would be perfect. I dont think a cig lighter unit would work for our situation.
  11. Sep 13, 2020 at 1:38 PM
    timsp8
    NY
    Just got a cobra pro 1000w. The instructions say not to put it where there could be battery or flammable fumes. I guess there might be a tiny spark inside it when it kicks on or something. Just more to consider. I think I’m going to put mine under the drivers seat. It will be out of the elements and not too far from the battery.
    betotundra likes this.
  12. Sep 13, 2020 at 2:35 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I used velcro tape to put it under the rear seat.
    Ran 8g wire to it from the 80a relay. Relay is triggered by the dash switch.
    Havent run any 110v outlets yet.
    For now we can just plug in under the back seat pretty easily.
  13. Sep 14, 2020 at 5:00 PM
    timsp8
    NY
    I’m probably going to do the same thing. I put it under the drivers seat and it’s just a little too high and hits the bottom of the seat. I’m thinking maybe put it behind/under the rear drivers side seat and slide the sub over. Or where the factory jack is.
    Dragracer_Art[OP] likes this.
  14. Sep 14, 2020 at 5:06 PM
    berto40
    berto40 Always a noob.
    Tag...this looks like an interesting mod. I'd like to add this feature in the future.
  15. Sep 14, 2020 at 5:55 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Make sure you fuse the positive line from the battery ran into the cab. Close the battery as possible :thumbsup:
  16. Sep 18, 2020 at 9:27 PM
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    Do you plan on doing a install write up? I have power tool batteries need to be charged while I'm sitting in traffic on the way home. This would really help.
  17. Sep 18, 2020 at 9:57 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    I'm thinking of doing something like this, running 4g wire to the inverter, under the seat, running extension cables from the inverter, wired to a/c outlets, one for the rear seat console and one for the front seat console, double cab.
  18. Sep 18, 2020 at 10:54 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    I realize yours is 1K watt and the stock Tacoma is only 400w but that one is wired with some small ass wire (no bigger than 10g). The converter is under the center console and the outlet is in the bed, w/the wire running to it the same size as to the converter.
    Just food for thought for others.
  19. Sep 19, 2020 at 9:22 AM
    Rolling Biome
    Denver, CO
    It all depends on power and length of wire for the installation, particularly on the DC side. The heavy gauge wire from the battery to the inverter was per the manufacturer recommendation for mine. On the outlet side, you can use whatever is appropriate for what you're powering. A heavy duty extension cord from a home improvement store would work just fine.
  20. Sep 19, 2020 at 10:26 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    What are you powering with yours? I want one for Dewalt power tool charger, computer work stuff like network switch, wireless access point, lap tops. I had a new tacoma and FJ with the factory one but it was so small of inverter i tripped its circuit breaker about every time I tried to use it for anything.
  21. Sep 19, 2020 at 10:43 AM
    Rolling Biome
    Denver, CO
    Mine is overkill, honestly. I needed an inverter to power an air mattress inflator for camping trips but decided to future-proof in case I needed power for other devices.
  22. Sep 19, 2020 at 10:46 AM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    As someone who has installed thousands of inverters, I highly discourage locating it under the hood. Install it inside the passenger compartment with room for air to circulate.
  23. Sep 19, 2020 at 2:09 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    @Shark Bait - based on your experience, what are your recommendations for specific inverters including size and wire specs?
    Shark Bait likes this.
  24. Sep 19, 2020 at 2:39 PM
    Shark Bait
    David
    2019 Platinum
    A 1500 watt is what I do the most. Seems very accommodating to a lot of uses. 4 gauge wire for positive (fused for 150 amps) and ground to the battery. Mostly I have used Xantrex and Power Drive. I used to do a lot of 3000 (0ga wire and 300 amp fuse) and 5000 (dual 0ga with 300 amp on each one) and ground ran to battery as well. The Power Drive is inexpensive but they are really dependable.
  25. Sep 19, 2020 at 2:45 PM
    P-Factor
    P-Factor New Member
    I totally concur. :thumbsup:
  26. Sep 19, 2020 at 3:30 PM
    French Avocado
    Utah / Wyo
    @Shark Bait - thanks for the recommendations. This is on my list of future mods.
    P-Factor likes this.
  27. Sep 19, 2020 at 4:17 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Wasnt really interested in getting that involved.
    It takes me too much time already with my busy schedule to add in more pictures, explanations or tutorials.
    Ill let the youtube rockstars ( @2020Platinum ) handle that stuff. :thumbsup:
    2020Platinum likes this.
  28. Sep 19, 2020 at 7:58 PM
    soobahru
    soobahru New Member
    No worries. Now to incorporate solar panels. Haha
  29. Sep 19, 2020 at 8:45 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    This may be one of my next mods/videos...wasn’t really considering this but after reading this thread I can definitely picture it coming in handy!
  30. Sep 19, 2020 at 9:02 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    this is what i have done. 2 100w panels, 170 aH lithium battery, a 2k inverter and a DC-DC mppt controller. gives me plenty to power studio strobes, charge batteries and run the fridge.
