Power folding mod
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tripj86, Feb 19, 2016.
  1. Feb 19, 2016 at 6:15 PM
    Tripj86
    Tripj86 [OP] New Member
    Josh
    '15 Limited CM 4x4
    6" RCX Lift on 35's
    Need some info, checked the whole thread on 14+ and can't find any info on changing to power folding mirrors. I am wanting to go to power folding on my A'15 LIMITED. Anyone tell me what is needed to upgrade to power folding mirrors, besides the obvious, new mirrors and switch. I've already bought both, just haven't installed yet. Will I need to do some wiring, or will it be a plug and play? Thank you for any assistance.
  2. Feb 20, 2016 at 7:23 AM
    usmp97
    usmp97 New Member
    2019 Silver Sky CM Platinum
    Sold ‘15 CM
    So...through TundraCrew on Facebook...they had a thread in February. It actually references "another" tundra forum. Give me a few and I will get the link.
  3. Feb 20, 2016 at 7:25 AM
    usmp97
    usmp97 New Member
    Sold ‘15 CM
  4. Feb 20, 2016 at 7:35 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    @csuviper did this on his 2nd gen. Sure he can help.
  5. Feb 20, 2016 at 7:51 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Limiteds don't have folding mirrors? huh
    Install the mirrors and the switch, if it's pre-wired, then you're done. If they don't work, then you'll have to run the wiring yourself following the thread linked above.
  6. Feb 20, 2016 at 11:11 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have not completed it yet. Just installed the mirrors and the switch. Still needs wires added for the power fold and the bottom lights.
  7. Feb 20, 2016 at 5:56 PM
    Tripj86
    Josh
    '15 Limited CM 4x4
    6" RCX Lift on 35's
    Thanx for the info. That's what I'll do, hook up and hope, if not I'll make it work. I'll post up my findings once all is finished. Most likely won't get to it till middle of next month. I work offshore and am heading out on Tuesday
  8. Feb 20, 2016 at 6:51 PM
    csuviper
    Broomfield, CO
    Limiteds should come with the folding mirrors. That is where I got my folding ones from. On from someone that switched to tow mirrors, one from a wrecked limited.
  9. Feb 20, 2016 at 6:59 PM
    But limiteds don't, platinums do.
  10. Feb 20, 2016 at 7:25 PM
    Tripj86
    Josh
    '15 Limited CM 4x4
    6" RCX Lift on 35's
    I found a set of tow mirrors, with power everything, including power folding and defrost for $375
  11. Apr 30, 2018 at 10:37 AM
    csuviper
    Broomfield, CO
  12. Apr 30, 2018 at 7:37 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Power folding was on Limiteds up to 2012 I believe. Currently only Plat and 1794 have them OEM.
