Power Fold Mirror
Discussion in '2nd Gen Tundras (2007-2013)' started by shukvegas, Sep 9, 2015.
  1. Sep 9, 2015 at 10:38 AM
    shukvegas
    shukvegas [OP] New Member
    2011 Tundra Crewmax Platinum
    When my driver side mirror is power folded, it makes contact with the door window. Is there a way to adjust so it doesn't hit or something I should check? Thank you.
  2. Sep 9, 2015 at 12:54 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Roll down the window? lol
    I wonder if there's a "stop" on the inside that is broken. That may require getting inside the mirror to investigate.
  3. Sep 9, 2015 at 1:07 PM
    shukvegas
    That is what I was thinking. Just don't know how to get to the stop.
  4. Sep 9, 2015 at 2:49 PM
    There's gotta be some sensor or something that needs adjustment / repair.
  5. Sep 9, 2015 at 4:24 PM
    shukvegas
    I pulled all the panels i could and didn't see anything that could be adjusted. I hope i don't have to buy a new mirror.
  6. Sep 9, 2015 at 8:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I might go so far as to speculate that there might be a set of contacts that either open or close when the mirror gets to the end of its travel to tell the motor to stop running. They may be bent slightly. It may be that at some point in time, someone folded or extended the mirror manually and the internal mechanism is "a cog off". I've never had my mirrors apart, so....speculation is about all I have for you. I do know that the mirror glass is replaceable, removing that may enable you to see more of the internal workings. I don't know the details of it's removal either though...
